[ICEM] Script: problems with face names
Old   May 20, 2011, 10:48
Question Script: problems with face names
Martin Weil Brenner
Maweil is on a distinguished road
I'm building an iteration loop where ICEM script is called to mesh my geometry.
The geometry is generated in Catia using a VBA script and the resulting geometry always have a similar topology (the face, curve and point count are always the same). Then, the geometry is exported as an IGES file (a clean solid shell) to ICEM. My problem is that between iterations, the surfaces, curves and points naming in ICEM are (sometime) different which crash my script. I'm using refinement applied to surfaces and these surfaces name (in the " F_### " form) appear in my script, when face name change it crash.
I'm currently trying to find and testing solutions to either fix the topology name or to bypass the problem in my script.
I'd like your suggestion about this problem, if you already encountered it and if there is known or possible solutions.
Tanks You,
Martin Weil Brenner
Maweil is offline   Reply With Quote
Old   October 13, 2011, 04:46
Default problems with curve names
Sebastian Knight
basti is on a distinguished road
Hello Martin,
I do a similar work. My task is to write a script wich automates loading geometrie (IGES-File), blocking, refining and after all saving the mesh. It should work for geometries that are slightly different. The problem is, that ICEM is renaming the curves any time I run the script (and thus loading the new geometry), so the script canīt be completed.
I read that you had the same problems with surface-names. Do you meanwhile have an solution to deal with that problems in the script?
Thank you
Sebastian
basti is offline   Reply With Quote
Old   October 25, 2011, 21:32
Martin Weil Brenner
Actually the problem is the same for surface/curve/point.
I solved my problem using a software called CAPRI which is a "gateway" to Catia. It is then possible to convert a .CATpart to .tin and surface/curve/point name are static if topology remain the same. If part size change but CATIA tree remain the same it work very well. Using this software I also created a script which modify parameters value and regenerate the part. The software is distributed by http://www.cadnexus.com/
Martin
Old   April 16, 2019, 09:10
Varun
varunraju is on a distinguished road
Hi guys,
I am also facing similar problem. Just curious to know is there any alternative rather than to rely on another third party vendor for getting the correct name selections for similar topology
varunraju is offline   Reply With Quote
face, icem, script, topology
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 18:25
Face merging, patch definition, wall function Sandu69 OpenFOAM 2 March 24, 2010 11:48
Face orientation in blockMesh WiWo OpenFOAM 0 March 18, 2010 11:10
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
