[Other] Mesh generation method for coil heated within shell
Old   June 8, 2011, 09:03
Post Mesh generation method for coil heated within shell
Mehdi Asghari
Asghari_M is on a distinguished road
Hi All.
I am modelling a coil within a hot water. I presented a geometry model in attachment for anybody who is willing to see it.
I goanna model it by fluent and Gambit software (recently Ansys) .
The fluid within coil is heated by hot water circulating over the coil. Therefore the coil is heated. The main questions are presented as follows:
1-Which solver's model is suitable for this purpose?
(For example, is the Heat exchanger model suitable for this object?)
2-Am I allowable to use a 2D model for coil as well as a 3D model for water in shell? Which mesh generating method is suitable for volume in shell?
3- Which boundary condition can be used as oulet boundary of coil (I think I can't use a Neumann boundary condition specially since coil is being heated till discharge)?
Note that the side walls are adiabatic.
Thanks in advance for any suggestion.
Asghari_M is offline   Reply With Quote
Mesh generation software is needed H.Dou Main CFD Forum 12 May 4, 2011 16:20
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
3-d elliptic generation mesh Gang Sun Main CFD Forum 5 September 16, 1998 01:24
