[DesignModeler] Sketching from entities in an imported body (SolidWorks Interface)
Old   June 9, 2011, 15:41
Default Sketching from entities in an imported body (SolidWorks Interface)
Thomas Clark
t_clark is on a distinguished road
I have a problem with the Solidworks Geometry interface - line bodies are not being imported. BladeModeler/DesignModeler is attached to an active Solidworks model. This successfully imports the model, and parameter changes are successful - i.e. the bidirectional capability is working. I have the 'Import Line Bodies' option turned on.
In DM, I have 3D bodies imported from my solidworks part (which is a duct, diffuser and hub geometry for a turbine). I'd like to add some turbine blades using bladeEditor, so need to define a flowpath.
First problem was that, when defining my flowpath, I could not pick up the edges defining the hub and shroud contours from the solid body.
Upon further investigation, I found that I need the profile of the hub and shroud (and inlet/outlet) contained in sketches in DesignModeler, which I can then use to define the flowpath.
However, for the life of me I can't find a way of copying an edge of the solid body to be a curve in a DM sketch.
As I understood it, the 'Import Line Bodies' option in the SolidWorks interface to mean that sketches are copied through as well. That's clearly not the case. As it stands, I can't even recreate the sketches I need by overdrawing them - as I can't snap sketch entities to edges or points on the imported solid body, or associate dimensions between SW and DM
Does anyone know how to get the interface to work? Or can anybody think of a workaround?
I could import via IGES etc but would lose my parametric description of the model, which I need for the next optimisation step.
Thanks for any help you can offer,
Cheers,
Tom
t_clark is offline   Reply With Quote
Old   February 26, 2013, 06:11
Default flow path sketching problem
vaghar
m.r.vaghar is on a distinguished road
hi Tom
I have problem to define flow path and I couldn't pick up any contour as hub/shroud/inlet/outlet in my blade, would u please introduce more this step.
thanks
Vaghar
Originally Posted by t_clark View Post
Cheers,
Tom
m.r.vaghar is offline   Reply With Quote
Old   January 30, 2014, 06:21
lauda
lauda is on a distinguished road
I'm having difficulties in exporting my geometry (radial turbine blade) in turbogrid. I have a STEP file that I can open in Design Modeler. Now, if I have understood well, I need to create sketches in order to define a flow path. As suggested, these sketches should be drawn in X-Z plane. This is not very clear to me. For instance, the hub sketch would be simply the camber line of the hub in the meridional view? In this case how does turbogrid understand the variation of thickenss from hub to tip? I would say that the hub sketch should be a closed curve in drrawn in 3D and not only in X-Z plane. Is that right? I would appreciate any clarification. Many thanks.
lauda is offline   Reply With Quote
designmodeler, flow path, geometry interface, line body, solidworks
Imported ICEM mesh has additional body in the mesh Procyon CFX 1 January 27, 2011 16:21
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
