[ICEM] airflow in an annular space between outer and inner pipe
Like Tree10Likes
Old   February 20, 2013, 05:05
Default airflow in an annular space between outer and inner pipe
ahmad
malay is on a distinguished road
I need your expertise for my case, I have airflow in an annular space between outer and inner pipe with sudden expansion (inner pipe solid and one part heated and second part unheated. I have problem with interior part for meshing thus as I make blocking for each part and meshing then the interior part remain without mesh. Please can you solve this problem and export the mesh to fluent because some time the fluent give me error such as non-positive volume. Please find the attach file with ICEM
I will appreciate your help and looking forward receiving your communications
Thanking you
malay is offline   Reply With Quote
Old   February 20, 2013, 06:23
htokan
htokan is on a distinguished road
Thanking you
I think Mr Simon can help you beacuse he has good experince in icem
htokan is offline   Reply With Quote
Old   February 20, 2013, 08:26
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Here you go
malay likes this.
Far is offline   Reply With Quote
Old   February 20, 2013, 12:05
ahmad
Dear Sir Far,
Firstly, a lot of thanks for you, My dear brother earlier I reached this step from the project but still same problem interior without mesh and also when I import mesh in fluent there is error (non-positive volume) Please I need from you meshing the interior and import the fluent without error (non-positive volume). Finally I need you to write me all the steps you will do it. Please find the attach file involve two picture for my case
Thanking you
Yours sincerely
Old   February 20, 2013, 12:10
Wink
htokan
Dear Sir Far,
Thanking you
Yours sincerely
I said to you only simon can solve your proplem kidding
Old   February 20, 2013, 12:17
Far
Sijal
Ok. You need mesh inside ?
malay likes this.
Old   February 20, 2013, 12:24
ahmad
my Dear brother, still interior without mesh. Please see the attach file
Thanking you
Old   February 20, 2013, 12:27
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Project here :
https://dl.dropbox.com/u/35161486/case.zip
PSYMN, BrolY and malay like this.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   February 20, 2013, 12:32
Far
Sijal
Hey
You really need mesh in interior (and please don't use the word which is already reserved for some other purpose, it makes confusion )
If you give it boundary (wall) your flow will not flow from this boundary, or if you give it as inlet or outlet it will be mathematically wrong. Trick is " associate face to surface"
I also want to know do you need inside the solid part?
Otherwise mesh is perfectly fine.
malay likes this.
Old   February 20, 2013, 12:38
ahmad
Originally Posted by diamondx View Post
Many thanks Mr. diamondx now I am trying in fluent just waiting me please
Old   February 20, 2013, 12:40
ahmad
Hey
Dear Mr. Far, air flow between space annular and exit pipe make sudden expansion and interior meaning (fluid) between two entrance and exit pipe
Old   February 20, 2013, 12:46
Far
Sijal
Thanking you
Interior (Fluid) is always without mesh. But you can turn it on if needed.
malay likes this.
Old   February 20, 2013, 12:50
ahmad
Dear Mr. Diamondx Please find the picture I need block around the inner pipe by ogrid beacsue in fluent need to define heat and unheat pipe
Thanking you
Old   February 20, 2013, 13:01
ahmad
Please Mr. Far I need Interior part beacsue it has beganing recirculation zone
Thanking you
Old   February 20, 2013, 13:13
htokan
Thanking you
I got your point Please see the picture
Old   February 20, 2013, 13:27
diamondx's Avatar
Ghazlani M. Ali
You need suface first...
malay likes this.
Regards,
Ali
Old   February 20, 2013, 13:45
Far
Sijal
Thanking you
Do you need blocks around or inside?
Have you gone through ICEM CFD tutorials?
Old   February 20, 2013, 13:47
ahmad
yes bro ....
Old   February 20, 2013, 14:14
ahmad
Dear Diamondx,
I import the mesh file in fluent and apply boundary condtion but as 3 iteration i got divergance as shown in attach picture
Old   February 20, 2013, 15:23
htokan
I said only Simon he has ability to solve this problem. Where is simon ??we waiting solving....
