June 22, 2011, 10:37 |
Similar tetra refinement
Andreas P
Rep Power: 15 |
Hi all!
Somehow I can't believe I need to ask this because it seems trivial, but we are not getting the solution we want, so here's the question: We have a 3D mesh consisting purely of tetra elements. Now we want to refine this complete mesh with a similarity approach. That means, each tetra of the old mesh should be subdivided into 8 new ones, which are all similar to their "father". Thus, each edge should be split at its center into two new ones. The newly created nodes shall NOT be projected to the geometry surfaces. They should just stay at the same place where the former edge center used to be. To me this really seems to be the simplest mesh refinement one could do. But how is it possible with ICEM??? Any help is appreciated! Andreas |
June 22, 2011, 11:21 |
Andreas P
Rep Power: 15 |
Maybe to shed a little more light on that issue:
We have tried the "Pure mesh refinement" method from the refine/coarsen menu. See the attached pngs for an example. For the element marked in blue, the method seems to do what we want. At least the marked triangle is split into 4 as we desire. However, the red element is refined awkwardly. Why? Do we have to explicitly tell ICEM to use the most simple dividing algorithm? If so, how can we do it? Again, thanks in advance for any help! |
June 24, 2011, 12:35 |
Different way to get there...
Simon Pereira
Rep Power: 47 |
Under change mesh type, you could "add midside nodes". Turn off projection so they won't snap to surface.
Then "remove midside nodes" and use the option to convert to multiple linear elements... It should give you exactly what you want.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
June 27, 2011, 04:22 |
Andreas P
Rep Power: 15 |
Perfect, that did the job!
Thanks! |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 08:07 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
[snappyHexMesh] sMH refinement level | subhkirti | OpenFOAM Meshing & Mesh Conversion | 0 | October 13, 2010 04:10 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
