August 3, 2011, 04:49 |
face common to volume
prince
Rep Power: 14 |
during construction of geometry in gambit, i come across peculiar problem. However, i found the solution but its lengthy process
i was making a common header with 10 nozzles mounted on it. I need to use hexa mesh, so i divided my geometry like this. I have drawn two rectangle of dimension such as one lie inside the circle (dia 0.2 m) and one lie outside the circle. I have joined the corners of rectangle. After that using split edge tool. i split the recently drawn four edges with circle (using bidirectional option while splitting edges). This way circle is divided into five parts. I used the create face from wire frame tool and made the edges into faces. (Using edges of small rectangle and arc of circle. middle face will entirely form from rectangle edges). Now my circle is divided into five faces. I used the sweep command to make 5 volumes from five faces. Now, two make other nozzle i simply copied the circle faces (which is divided into 5 parts) and sweep it. My problem is that when i use sweep option to the copied faces, the volumes which share common face has two different face (one for each volume i.e common face is drawn twice). but there should be only one face which is common to two volumes. I cant merge the faces as it is giving error. This problem can be eliminated if we do not copy the faces. Make new circle and divide in into five parts and then sweep. My geometry has number of nozzles and it will b difficult to make same thing again and again. Any suggestion ?? |
August 3, 2011, 06:00 |
Maxime Perelli
Rep Power: 41 |
connect/face
PS: adding a picture may help to understand
In memory of my friend Hervé: CFD engineer & freerider |
August 4, 2011, 04:22 |
prince
Rep Power: 14 |
hello max..
I will try to upload the pic.. Thanks for replying. |
August 8, 2011, 03:05 |
prince
Rep Power: 14 |
Hi..
i am attaching two diagrams. One with mesh and one without mesh. |
August 8, 2011, 03:23 |
Maxime Perelli
Rep Power: 41 |
Did you connect all surfaces?
Enable color Mode: http://my.fit.edu/itresources/manual...ide/ug0304.htm And repost left picture color mode enabled
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
why i can't split a real volume with a virtual face. | George Chen 28 | Main CFD Forum | 0 | March 8, 2010 03:41 |
Split volume with a face error | Duncan | FLUENT | 1 | October 25, 2005 13:45 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
