August 28, 2011, 05:17 |
Blocking
Mohankumar.G
Rep Power: 16 |
I am doing blocking for a part and my doubt is something similar to the example shown here. If we have a sudden enlarged pipe like this we have to split the block to capture the bigger diameter and the smaller diameter and if we created a O-grid to get a good mesh, then at the enlarged section the quality of mesh is very poor. If we create 3 or 4 O- grids inside to capture the features inside a cylindrical part then it will becomes much complicated and the quality is even worst. Kindly any one help me how to solve this problem. Thanks in advance. |
August 30, 2011, 11:00 |
AB
Rep Power: 21 |
- Create a first O-grid for your global geometry
- Cut it at the jonction of your 2 tubes. - Create another O-grid for your global geometry inside the first one to capture the small tube. - Delete the blocks around your small tube. You can do another o-grid inside the small tube to increase the quality |
[ICEM] o grid blocking strategy? | icemaniac178 | ANSYS Meshing & Geometry | 14 | March 19, 2013 23:18 |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 03:13 |
[ICEM] Blocking of 2 cylinders | FrankW | ANSYS Meshing & Geometry | 5 | April 14, 2011 10:49 |
[ICEM] Blocking strategy | BrolY | ANSYS Meshing & Geometry | 0 | July 22, 2010 04:46 |
Mesh is created in blocking | Severin | CFX | 3 | September 18, 2007 09:02 |
