[DesignModeler] problem using revolve
Old   September 1, 2011, 07:33
Default problem using revolve
Benjamin
elys is on a distinguished road
Dear all,
I have a problem concerning the revolve feature in Ansys' DesignModeler: I have managed to import points from a text file which I want to use to create a revolved geometry. I can import the points as a 3D Curve or as regular points which I can than convert to a line. So far so good, however, I can't apply the revolve feature because I cannot select a base object (which is usually a sketch - If I draw a polyline manually then I can use revolve without any problems, but I like to apply this feature to the imported points). What do I miss here? This must be easy I am using Ansys 13 SP1
Any help is greatly appreciated!
Thanks in advance,
Ben
elys is offline   Reply With Quote
Old   September 2, 2011, 08:15
Default [Solved] revolve from 3D Curve
Benjamin
I just found out by myself. It is, as I already assumed, quite easy: Just apply a Named Selection to the curve first, then it is possible to use any feature like revolve or skin/Loft, etc.
This is for my understanding not very intuitive, but if you know that it is ok.
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
