[ICEM] Mesh reflection to obtain perfectly symmetric grid |
September 15, 2011, 15:33 |
Charles de Luzan
Hello everybody,
Is anyone able to give me some advice on this? Thank you very much in advance |
September 15, 2011, 22:41 |
Bruno
Rep Power: 21 |
What type of errors?
September 16, 2011, 04:50 |
AB
Rep Power: 21 |
Do you try to merge the blocking or the mesh ?
Because you can rotate your blocking and avoid to merge two meshes. Anyway, if you merge two meshes, be careful to the mesh law of your edges. Because if you specified a "geometric 1" law on one edge of your symmetry plane, you would have issues to merge the 2 meshes once you have make a symmetry of your mesh 1. The edge of your mesh 1 would have to be merged with the same edge of your mesh 2, but with the symmetry operation, the orientation of your edge would have changed. And with a geometric 1 law, the nodes on those edges won't be aligned anymore ! |
September 16, 2011, 11:11 |
Simon Pereira
Rep Power: 47 |
Are you mirroring the blocking or just the mesh? If it is topologically symmetrical, but not geometrically symmetrical, you should mirror the blocking and then adjust to fit the actual geometry... But if it is geometrically symmetrical, you can just mirror the mesh, then merge nodes with a tolerance and delete the symmetry shells.
I don't think you should have a problem with your mesh distribution laws (as BroleY was talking about) if you mirror, but only if you copy rotate by 180 (which I hope is not what you are doing). For more help than this, you will need to tell us what the errors were.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
September 21, 2011, 18:54 |
Charles de Luzan
Thanks everybody for your interest and your help,
Thank you again! |
September 21, 2011, 21:18 |
Simon Pereira
Rep Power: 47 |
When you mirrored the mesh, you have a duplicate symmetry plane. You need to merge nodes with a tolerance (set to something very small like 1% of you mesh size) and then delete the elements in your symmetry part.
Then run your checks again and you should be fine. Yes, other issues deserve other threads...
September 22, 2011, 13:00 |
Charles de Luzan
Ok I am doing this, thank you so much.
December 11, 2014, 07:47 |
Ahmed El-Sawi
Rep Power: 11 |
As i have almost the same problem how do i delete the symmetric shell? i already chose the option of merge nodes and delete duplicated elements while using the mirror option? is this not enough and what should i do more to get rid of multiple edges and non-manifold vertices. thank you very much
December 11, 2014, 11:04 |
Simon Pereira
Rep Power: 47 |
Assuming the symmetric shell is in a unique part name (such as "SYMM") you can turn off all the other parts and just delete the elements.
There are a bunch of element selection options, so if you don't want to drag a box to select, you could delete visible or delete by part or draw a polygon around the elements you want to delete. This will just delete the shells and not the volume elements on either side.
December 11, 2014, 11:22 |
#11 |
Simon Pereira
Rep Power: 47 |
Yup that works too... And by keeping those shells as interior, you can more easily post process on them.
3d mesh, icem cfd, merge, reflection, symmetry |
On grid independent solution for pulsatile flow | David | FLUENT | 5 | March 25, 2022 04:33 |
Mesh grid a propeller with Gambit | vsun | ANSYS Meshing & Geometry | 0 | October 26, 2009 01:44 |
Obtain Geometry Data from a Grid File in CFX 10.0 | ARJUN | CFX | 2 | August 17, 2006 08:20 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 06:59 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 12:18 |
