October 6, 2011, 15:39 |
Shared Topology Calc Time
ej
I am using Ansys 13.0 designmodeler and have a large scale model with a single part made of 3556 bodies.
I am experiencing a very high lag time (2+ hrs.) when attempting to transfer this "clean" model into the Ansys meshing application. This lag time is also experienced when employing the "shared topology" command in DM. Does anyone know how to maximize settings within Workbench to speed the transfer process of a multi-part body from DM into the mesher? Or is there another method to transfer a large model into the Ansys meshing application to generate a conforming mesh without sacrificing high amounts of time? I am on a windows 64 machine with 12 cores and 48 GB or ram. Thanks for any advice. |
November 13, 2013, 01:19 |
Copper
I had the very same problem...have you solved this problem out? Thank you. |
designmodeler, large scale model, meshing, shared topology |
Time step size and max iterations per time step | pUl| | FLUENT | 33 | October 23, 2020 22:50 |
Hydrostatic Pressure and Gravity | miliante | OpenFOAM Running, Solving & CFD | 132 | October 7, 2012 22:50 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
unsteady calcs in FLUENT | Sanjay Padhiar | Main CFD Forum | 1 | March 31, 1999 12:32 |
