July 26, 2010, 07:56 |
Gambit GUI slow response in Win 7
Petr Jurcicek
Rep Power: 16 |
Dear fellows:
recently, I'm dealing with a very annoying problem with a very slow response of buttons and GUI commands in Gambit . I use the exceed v.9 in Win 7 x64. I have to run the Exceed manually but it's not such big a deal. I've tried to set-up some parameters of the Exceed in its preferences (Xconfig) but, still, the problem holds. Still, I tried to emulate winXP with employing the compatibility mode for both, exceed and Gambit, unfortunatelly, with no positive result Any experience or hints ? Appreciate any help. Thx. Pete. |
July 30, 2010, 07:11 |
Rep Power: 17 |
i'm afraid the version of exceed you are using is rather old.
you probably have better use exceed 14 (v2008). |
July 31, 2010, 03:19 |
solved
Petr Jurcicek
Rep Power: 16 |
Thank you doki for your reply.
I solved the problem by setting the Exceed config from 'multiple window mode' to 'single window mode' and the problem is more or less solved. However, other less significant problems arose with the graphics but it is ok. The environment is as fast as in WinXP |
October 28, 2011, 08:49 |
Emre G
Rep Power: 14 |
hi.. i have same problem.. please help me, what should i do without changing any video datas.
October 28, 2011, 21:34 |
Petr Jurcicek
Rep Power: 16 |
Hi emreg,
first, you could try to change your Exceed version (reinstall). Exceed is responsible for the graphics for Gambit. My problem was in Windows 7 x64. 32bit version's maybe better because of compatibility. Gambit is simply too old, so it becomes a problem. You can try to run virtual PC with windows XP (just for meshing), another solution. Next way is to use newer version of Fluent (In Ansys pack v12). You will have absolutely no problem then. Cheers, Peter |
October 30, 2011, 06:00 |
Emre G
Rep Power: 14 |
thanks for all,
i would like to ask you if you know a website to download the proper Exceed version. i am using exceed 13.0 . best regards, emre gungor |
exceed, gambit, gui, response, slow |
GAMBIT + win7 = Very slow performance | rieuk | ANSYS Meshing & Geometry | 3 | September 6, 2017 02:41 |
tips for runing Gambit without Exceed in Win Vista | Fabio Saltara | FLUENT | 9 | September 23, 2011 13:59 |
[GAMBIT] Gambit start win vista? | ferranpm | ANSYS Meshing & Geometry | 1 | June 8, 2009 16:23 |
No font in Gambit GUI menus | Gijsbert Wierink | FLUENT | 0 | October 8, 2008 04:25 |
GAMBIT and win xp | Philip | FLUENT | 10 | January 1, 2007 13:33 |
