[ICEM] Problem with "cooper" (sweep) mesh
Like Tree1Likes
  • 1 Post By Twix
Old   October 18, 2011, 15:56
Default Problem with "cooper" (sweep) mesh
doodek is on a distinguished road
I've a problem with meshing my geometry attatched at link below (one surface is invisible in the figure).
http://imageshack.us/photo/my-images/69/unledkhi.png/
I would like to mesh two volumes: one is a little cylinder (volume 1), and the second is bigger cylinder with a hole inside (volume 2). I want to use scheme, which names 'Cooper' in Gambit, so it is necessary to mesh for example bottom surface (all quads) and sweep the mesh in normal direction to the end of the geometry (with increasing distance between nodes).
I can't make a block for volume 2, because there is a hole, so the mesh doesn't take into account inner cylinder. How to do this?
I would be grateful for your suggestions.
Regards,
doodek
doodek is offline   Reply With Quote
Old   October 19, 2011, 01:29
Sushilkumar is on a distinguished road
You can split your lower cylinder with the same hole size in it and then you can proceed with the desired meshing.
Sushilkumar is offline   Reply With Quote
Old   October 19, 2011, 02:16
Thanks for your reply Sushilkumar.
I don't understand your idea. Could you specify what did you mean by?
Old   October 20, 2011, 03:39
You can make the inner cylindrical part extend to the ends and then you have 3 volumes.
two annular ring like volumes and one solid cylinder(for lower part). These three parts can be easily meshed then.
Hope it is clear now.
Old   October 25, 2011, 12:42
Ok, but how to mesh cylinder in cylinder with O-grid in both cylinders by blocking? I can create mesh with O-grid structure in bigger cylinder, but in smaller I can't assign O-grid. Could anybody help with this simple problem?
Regards,
doodek
Old   October 26, 2011, 04:00
Michal
Twix is on a distinguished road
Hi
You can create block on lower cylinder, then create first O-grid, next second O-grid on internal block and then extrude block faces (1,2,3,4) to create blocking on upper cylinder with hole inside.
Regards
doodek likes this.
Twix is offline   Reply With Quote
Old   October 27, 2011, 10:07
Thanks for reply. It works.
By the way: I would like to mesh these volumes using surface mesh and extruding. So: firstly bigger at the bottom was meshed (surface with hole), and then this hole (small surface) was meshed also. Next step is extruding mesh from surface with hole and extruding mesh from small surface inside. Visually all looks good, but check mesh procedure shows that in the mesh are missing internal faces. How to fix it?
Regards,
doodek
Old   October 28, 2011, 04:48
Michal
Hi
In my opinion blocking is the best way to generate hex mesh because you have better control on e.g. node distribution. This is strange because missing internal faces error appears when your meshes are in different parts, and I don’t know how to fix it. I assume that you want to generate Quad Dominant mesh so you will get similar results by changing block types to swept. To do so, go to Blocking->Edit Block->Convert Block Type.
Regards
2D mesh extraction problem Caner STAR-CCM+ 0 June 22, 2011 05:33
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
problem when converting mesh (made by ICEM) using fluentMeshToFoam Forrest_Lei OpenFOAM 11 October 16, 2009 06:28
[GAMBIT] Problem with mesh. Please Help... maziboss ANSYS Meshing & Geometry 1 September 28, 2009 02:24
The problem with GAMBIT - using two mesh sizes. Owen FLUENT 2 June 22, 2005 05:16
