[DesignModeler] merge/virtual topology problem |
October 30, 2011, 07:21 |
BaBa-Firat
Rep Power: 14 |
Hi
I have a problem with my geometry which I have formed using CATIA v5. Please imagine my geometry that, there is a body and there are another two bodies on the first body. So one face of the first body is in contact with totaly two faces of other two bodies. And I formed one part and three bodies with these parts. When I import geometry into design modeller, the face of the first body (in contact with two faces of other two body), is single (that is no need to merge).But when ı continue with ansys/meshing, I see that this face (in contact with two faces of other two body), is divided into two. So I tried to use virtual face but it gave an error. But as I said first I can not see these two faces at design modeller (they is on face). So I can not use sweep method. What is the problem. Thanks in advanced. Fırat |
Problem with interFoam; Wave/wiggle alpha1 behavior | JonW | OpenFOAM | 10 | February 4, 2023 07:27 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 08:39 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
