[ANSYS Meshing] Ansys Meshing Error on Generation |
November 16, 2011, 14:44 |
Reggie Rivera
Hi guys,
Just learning CFD from Ansys Tutorials. When coming up to the Mesh Update on page 1-21 (Point 4), am getting an error "an inter-process communication error occured while communicating with the MESHER module." ... (Application: Project>Module). Any idea how to get around this. I am using Ansys 13.0 (Magnitude) 64 bit version. Thanks Same geometry and tutorial steps work on a Ansys 13.0 (64 bit) academic version install in Uni. ... Last edited by resnik; November 16, 2011 at 14:48. Reason: Addendum |
November 16, 2011, 18:29 |
raj
It can be either license error ( between workbench, geometry/design modeler and meshing)or the way the software has been installed. Probably you can re-install . More-over check for the ansys software minimum requirements like hardware, OS , RAM etc. |
July 15, 2015, 07:26 |
I had the same problem.
The tutorial said to put 6e-3 for the element size, supposing you're in meter. The fact is you're in millimeter by default. Put 6 mm instead. The mesh is really to big with 6e-3 mm and the problem is maybe associated to the available memory. Sorry for the english, I'm french native. Bye |
February 14, 2024, 23:43 |
ahmed
I faced the same problem, I was changing the shared topology from none to imprints in DM. I got the same message while doing meshing. Then I deleted all the names from the name selection, after that, I did the meshing again but didn't get the error.
inter-process-comm-error |
2d meshing in ansys meshing | syler3321 | ANSYS Meshing & Geometry | 10 | November 1, 2012 20:42 |
How To save a created mesh file in Ansys Meshing | ashtonJ | CFX | 4 | January 7, 2012 22:04 |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
[ANSYS Meshing] Ansys meshing with extended meshing | jsm | ANSYS Meshing & Geometry | 6 | January 10, 2011 12:09 |
Latest news in mesh generation | Robert Schneiders | Main CFD Forum | 0 | March 2, 1999 04:07 |
