[ICEM] prametric geometry script
Like Tree1Likes
  • 1 Post By brunoc
Old   November 19, 2011, 19:31
Default prametric geometry script
skrzatchlewny is on a distinguished road
I would like to have a simple parametric geometry (translated circle). To do that I generated following Tcl script:
1: ic_vdefine r variable 2
2: ic_point {} GEOM pnt.00 0,0,0
3: ic_point {} GEOM pnt.01 1,0,0
4: ic_point {} GEOM pnt.02 1,1,0
5: ic_curve arc_ctr_rad GEOM crv.01 {pnt.01 pnt.02 pnt.00 r 0 360}
6: ic_move_geometry curve names crv.01 translate {0 r 0}
the problem is with line 6, the circle stays at initial position and no error is displayed. Does anybody know the reason/solution?
skrzatchlewny is offline   Reply With Quote
Old   November 22, 2011, 12:35
Bruno
brunoc is on a distinguished road
That's because {..} does not allow substitution inside the brackets. Use ".." instead and it should work:
1: set r 2
5: ic_curve arc_ctr_rad GEOM crv.01 "pnt.01 pnt.02 pnt.00 $r 0 360"
6: ic_move_geometry curve names crv.01 translate "0 $r 0"
Cheers
hadikhayyamian likes this.
brunoc is offline   Reply With Quote
Old   November 22, 2011, 15:33
That solved the problem. Thank you!
Old   March 28, 2012, 03:40
Felipe Mendes
Felipe Mendes is on a distinguished road
Hey guys,
I'm also doing a parametric script using Tcl.
Nevertheless, neither the while nor the for looping work:
while {$i < 10} {
puts "I dans le boucle: $i"
incr i
for {set i 0} {$i<5} {incr i} {
Do you know how to make it work?
Does anybody knows how to select some point or line in ICEM parametric language by specifying a location (like in ansys workbench)?
Thanks a lot!
Felipe Mendes is offline   Reply With Quote
Old   March 28, 2012, 15:35
try that code:
set i 0;
while {$i < 10} {\
ic_mess "I dans le boucle: $i";\
incr i;}
Old   March 29, 2012, 03:11
Felipe Mendes
Thanks!
It worked pretty well!
Old   May 14, 2012, 13:55
Khayyamian
hadikhayyamian is on a distinguished road
Hi Brunoc;
Thanks for your great help. I wonder if there is any book, ..... as a source for tcl/tk and its use in ICEM.
Regards.
hadikhayyamian is offline   Reply With Quote
icem, parametric geometry, scripting, tcl
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
[ICEM] Problem in geometry creation by script lavoz ANSYS Meshing & Geometry 4 March 12, 2010 10:56
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
creating geometry using "Script files" in ICEMCFD jaber Main CFD Forum 1 November 11, 2007 09:28
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
