[ANSYS Meshing] Ansys geometry generation via Ansys Workbench
Old   July 27, 2012, 07:49
Question Ansys geometry generation via Ansys Workbench
Amanda Maria Bizzinotto Ferreira
AmandaMBF is on a distinguished road
Send a message via Skype™ to AmandaMBF
Good Morning everyone,
I'm trying to do a fluid simulation over an Eppler 423 airfoil using Ansys Workbench - Fluent. I have to open the geometry section, import my airfoil curve and generate the geometry so I can mesh it. I'm following this tutorial https://confluence.cornell.edu/displ...oil+-+Geometry.
I could generate the curve, the surface, the grid and the grid surface. But then I have to create two lines, one horizontal line dividing the grid in half and one vertical line dividing the grid in half. I can create the horizontal line but I cannot create the vertical line. When I try to generate the line by selecting the sketch and generating the curve I have the error: "Boolean operation failed".
Does anybody know how can I fix it?
Thank you
AmandaMBF is offline   Reply With Quote
ansys workbench, boolean, geometry generation
Can't import geometry file from Icem CFD to Ansys Workbench Julien87 ANSYS Meshing & Geometry 1 July 19, 2011 16:50
ANSYS Workbench 11 backup problem, mechanicaldesign ANSYS 0 June 21, 2011 01:48
WorkBench Errors( Geometry not loading), Bad Autodyn cell template tolu ANSYS Meshing & Geometry 4 December 21, 2010 12:17
Export Heat Flux CFX -> ANSYS Workbench Freeman CFX 2 April 11, 2010 08:24
Ansys Workbench 10.0 Merkur CFX 1 June 16, 2006 06:19
