[ANSYS Meshing] 3d wind turbine mesh for multiphase simulation |
January 17, 2012, 18:20 |
Ming Cai
Rep Power: 15 |
Dear all
I'm trying to build a 3d mesh of wind turbine for multiphase simulation purpose. VOF model is gonna be applied. I need a very fine boundary layer so i'm thinking about build hexa mesh for turbine surface and boundary layer, Rest of the domain could be tetra mesh with larger sizes. I already have the geometry at hand. Then I'm going to: 1. build 2d surface blocking for surface mesh 2. use Delaunay to generate volume mesh 3. build prism layer. Is this the correct way to do it? I'm confused about how to get a boundary layer with blocking method. by the way, I'm using ICEM, and the mesh is gonna be used in Fluent Thanks for you guys in advance. |
CFD analysis on wind turbine rotor | Ken (Wind Turbine CFD Super Rookie) | Main CFD Forum | 45 | February 9, 2016 14:07 |
Sample Wind Turbine Rotor Mesh | nickmai123 | ANSYS Meshing & Geometry | 0 | July 16, 2011 04:16 |
Angular velocity in wind turbine simulation | vanni | Main CFD Forum | 1 | May 18, 2009 11:03 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Wind Turbine simulation | Bharat | FLUENT | 0 | August 18, 2005 04:38 |
