[GAMBIT] Need help with meshing 3D Delta wing |
January 18, 2012, 09:14 |
Tran Anh Tuan
I'm doing an analysis of a Delta wing at low speed ( when the airplane is landing) and I want to use Gambit to mesh the 3D Delta wing geometry. But I'm new to Gambit, so I'd like to ask you some questions
Here is my idea: http://www.flickr.com/photos/74522469@N03/6712831701/ I divide the flow area into some blocks like they are in the image: for the view from above, we can see that there are 8 sections, and the same for the side view. I'd like to have more mesh at the angles of delta wing. Thus, can you tell me how can i do it step by step ? I don't know how to create those 8 sections. Should I create points then connect them by Virtual line ?? I only simulated a 2D Naca airfoil. But for this case, I don't know how to do. Please help me . I'm looking forward to seeing your reply. Thank you in advance. |
January 19, 2012, 10:12 |
Tran Anh Tuan
http://www.flickr.com/photos/74522469@N03/6725839671/
This is the 3D drawing geometry. Although it's an incomplete drawing, but i hope it's not difficult to understand |
January 19, 2012, 10:44 |
do you have coordinates of your wing? If not create them MS Excel, then we can import them in gambit and after that we can start our process.
As I see there are total four points on 2-d section. Is there any taper or change of chord length? |
January 20, 2012, 01:40 |
Tran Anh Tuan
looking down from above, the wing is a trapezoidal with the lengths of the parallel sides are 200mm and 2 mm, and the height is 172mm. The thickness of the wing is 2mm.
at present, there's no taper or change of chord length. I will count these ones in later simulation to compare. |
January 22, 2012, 00:33 |
Tran Anh Tuan
Still looking for some helps
January 22, 2012, 01:06 |
#7 | |
January 22, 2012, 03:38 |
Tran Anh Tuan
Thanks Far. I've already done that. So, what's the next step? Can u tell me the outline ?
January 22, 2012, 07:40 |
Tran Anh Tuan
flow is subsonic. The goal of this study is to research about the Delta wing at low speed ( when airplane is landing). After the simulation by ANSYS, I will compare that result to the experimental result ( using wind tunnel, so the speed is about 10, 15, 30 m/s)
January 23, 2012, 16:03 |
#11 |
make hemisphere domain from wing to at least 15 chords upstream and then connect with circular cylinder domain with at least 25 chords downstream. This is necessary since Reynolds number is very low and I am excepting higher angle of attack (correct me if I am wrong). Then subtract the wing volume from this far field body.
For quick simulation you may create the 3D boundary layer on wing and meshing the rest of domain with tetra. Flow is laminar, turbulent or transitional? Are you interested in resolving the separation? What other flow features are expected in flow? |
January 23, 2012, 22:34 |
#12 |
Tran Anh Tuan
I've already done the subtraction step. For the quick simulation, I can do it. However, I need to mesh the volume like the graphic which i sent above, but I don't know how to divide the flow domains like that to mesh them.
The flow is transitional and the AoA is high. Some pictures of delta wing simulation on the internet: http://www.onera.fr/photos-en/simula...ta-sillage.php http://www.google.com.vn/imgres?q=de...0&tx=110&ty=53 |
January 23, 2012, 23:12 |
hemisphere inlet
#13 |
The mesh topology you have just shown in above Fig. can be easily constructed and meshed within few minutes. I would like to suggest you to consider making the hemisphere in inlet region (as discussed above) in order to specify the high AOA.
I shall post some images and dbs file of your geometry today (if possible ). |
January 24, 2012, 11:19 |
#14 |
Tran Anh Tuan
Hehe, that sounds good . I'm looking forward to seeing it
January 24, 2012, 20:09 |
#16 |
Tran Anh Tuan
January 24, 2012, 21:21 |
#17 |
Although meshing was done by ICEM but same topology can be easily created within GAMBIT (obviously with more work of making vertices, edge, faces and may be volumes).
I am also sharing ICEM files here http://www.4shared.com/rar/w5TTdWKW/deltawing.html |
January 25, 2012, 19:21 |
#18 |
Tran Anh Tuan
Hehe, thank you so much. Let me see this first
January 29, 2012, 11:54 |
Meshing Double Delta Wing
#19 |
yatindra kashyap
Hi
I am working on the same problem of delta wing but it is double-delta wing I have meshed the surface of delta wing and the domain surface but getting problem on volume meshing of the domain......the problem is 32bit version ...? I need advice on this how to perform the meshing operation of the domain within 32bit limit......Using Gambit ,winxp,dual core,2gb |
January 29, 2012, 12:18 |
#20 | |
yatindra kashyap
https://rapidshare.com/files/1131190...fece_mesh2.rar also please tell me how to take snapshot of this delta wing from gambit |
[ICEM] Meshing a Flat Delta Wing | azurespirit | ANSYS Meshing & Geometry | 1 | August 28, 2014 08:11 |
[snappyHexMesh] Meshing 3D wing (hydrofoil) fails | klausb | OpenFOAM Meshing & Mesh Conversion | 0 | December 28, 2011 14:26 |
Wing Meshing | steve1 | ANSYS Meshing & Geometry | 1 | July 5, 2011 09:14 |
Wing meshing help...... | ACER | Main CFD Forum | 0 | January 31, 2011 18:20 |
Delta Wing Structured Grid | Riaan | FLUENT | 3 | December 31, 2004 12:03 |
