[ANSYS Meshing] stuck element vs prism layer
Old   January 12, 2012, 13:02
Default stuck element vs prism layer
hadrien calmet
hadrien51 is on a distinguished road
Hello Every body
I would like to mesh a boat with appendices. I would like a fine mesh
with good precision and small elements in the front and the tail of
the boat and in the appendices, plus the prism layers around the boat
and the apendices with different heigths. I use the following strategy:
-first the "surface mesh" is done with curvature,proximity based refinement,
all triangles, octree volume mesh. I delete all 3d elements and I run a
Laplace smoothing
-second I run a Delaunay volume mesh with the existing surface mesh, I
perform some smoothing with quality criterion
-third I create the prism layers all around the boat and appendices,
with "fix marching" toggle on and to finish I perform some smoothing,
freezing prisms and some with all types of elements, always with
quality criterion.
I obtain 25 M of elements , 5M of nodes and the quality is not
good. Of course the prisms decrease the quality, but the worse is
the prism generation produces some elements which occupy the same volume and
stuck elements.
I saw some post here about this problem, so I activated in advanced prism parameters "Prism v10.0" but it doesn't work
"Do checks" and "Do not allow sticking" but it doesn't work
I have always stuck elements.
I tried also without "fix marching direction" but it doesn't work
I tried also without laplace smoothing but it doesn't work
Other problem is the junction between the boat and the apendice with the prism layers.
I have attached a picture
Can anyone help or give me some advice ???
thank you
hadrien51 is offline   Reply With Quote
Old   January 13, 2012, 09:37
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
You just need to reduce the transition. The keel is much finer than the hull so it is having trouble with the transition. Refine the mesh on the keel for some distance out from the hull and it will be able to handle the corner... Then have it transition to the larger mesh size over some distance so the prism height transition will be smooth...
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   January 13, 2012, 11:58
hadrien calmet
Thank a lot Simon !
Old   January 18, 2012, 09:38
hadrien calmet
I reach to obtain 0 stuck elements !!!!!
- help the transition like Simon said
- don't forget to toogle on "do check", "not allowed ..."
-some layers(3) without height info
-split the 3 layers in 10 layers with "fix ratio"
-redistribute 10 layers with fix ratio
if this can help someone !
Old   January 23, 2012, 13:00
Default problem geometry
hadrien calmet
Hello
now, to no waste too much elements, I want to cut the hull to put prisms only on down part and decrease the size element on the top part.
So I produce curves on the intersection of one plan and the hull, I segment the surface hull with the plan (I tried to segment with the curves but it don't work !) , see fig 4.jpg.
I mesh the hull and I obtain this surface mesh (see figure 1,2,3 jpg).
I use the curvature on the down part and not on the top part (see 2.jpg).
Some one can explain me or help me to remove these horrible refinement in the intersection (see 1,3 jpg) and improve the edge (see 2.jpg)
Old   January 23, 2012, 13:02
hadrien calmet
ooops i forgot the pictures
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
ICEM Prism Layer transition between surface with prism layers and one without TWaung ANSYS Meshing & Geometry 2 October 12, 2009 14:56
Trimmer & prism layer peresah STAR-CCM+ 6 October 6, 2009 14:39
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
