[ANSYS Meshing] Negative elements along helix with triangular cross section
Old   August 1, 2019, 10:34
Default Negative elements along helix with triangular cross section
YorkshireTea is on a distinguished road
I am trying mesh a helical channel with triangular cross section, when I apply the mesh features to a much shorter section of the channel it works fine, when i try this on a full length channel i start to get negative elements at points along the rounded corners.
I'm using a boundary layer refinement for a K-w SST turbulence model
Please let me know if there are any files i can send for inspection
Rob
YorkshireTea is offline   Reply With Quote
Old   August 1, 2019, 15:02
Erik
evcelica is on a distinguished road
Try sweep mesh.
or
Slice body as shown to create mapped sweepable bodies, then create part.
Use sweep mesh with all quads from one end to the other.
evcelica is offline   Reply With Quote
[ANSYS Meshing] error:Zero or negative volume for elements. zhizhuo ANSYS Meshing & Geometry 0 November 27, 2017 06:25
[DesignModeler] Activate cross section to select radius item Ben_15 ANSYS Meshing & Geometry 0 March 12, 2017 06:47
flow in a nozzle with two narrowed cross section whitecat FLUENT 0 November 17, 2014 09:00
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
