[Other] Problematic Geometry- meshing with enclosure.
Old   February 2, 2011, 11:39
Default Problematic Geometry- meshing with enclosure.
Brendan
lev1athan is on a distinguished road
Hi guys!
Im trying to get CFD Analysis done with Ansys 12.1 through a section of a passenger aircraft cabin (15 rows of seats) which i modeled using Solid Edge ST.
The Cabin Geometry meshes successfully by itself, but when i create an 'enclosure' around it in the Design modeler i get a 'Problematic Geometry' error everytime with a random seat in the cabin.
I want to sucessfully simulate flow in FLUENT, by selecting one face of the enclosure as the Velocity inlet and the other face as the velocity outlet, but creating an enclosure around the geometry gives an error with the meshing everytime! However if i place an enclosure around a single seat or two, the geometry meshes sucessfully, but i need to simulate flow through the entire cabin.
Is there anyway i can get around this error?
lev1athan is offline   Reply With Quote
Old   February 3, 2011, 11:08
Default Contact tech support.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Sorry, not enough info to help you...
I suggest contacting tech support thru the customer portal or thru techsupp@ansys.com
You may need to send them the model for the quickest solution.
Best regards,
Simon
PSYMN is offline   Reply With Quote
Old   February 24, 2012, 16:24
Renee
rlipper1 is on a distinguished road
I know this post is a year old, but I wanted to add a suggestion to anyone else who might have a similar problem. First, make sure you "add frozen" under the operation menu (default is "add material") of the object you either imported or created in Designmodeler. If you did that, I also found that saving my CAD files as Parasolid makes a lot of "Problematic Geometry" errors go away when I import them. My experience is still limited, but maybe this post might help someone. Good Luck!
rlipper1 is offline   Reply With Quote
[ICEM] Geometry Tolerance and meshing Mitpostdoc ANSYS Meshing & Geometry 4 January 1, 2012 12:51
[ANSYS Meshing] Help - Meshing 2 Surfaces On A 2D Geometry Ali_M ANSYS Meshing & Geometry 4 March 29, 2011 03:01
Need help on meshing this simple geometry nha1g08 ANSYS Meshing & Geometry 3 March 9, 2011 02:13
Problematic Geometry fatb0y CFX 15 October 13, 2010 17:17
Problematic geometry error Jenny FLUENT 4 March 7, 2007 19:54
