[DesignModeler] Creating a blunt trailing edge from collapsed leading edge |
March 2, 2012, 09:48 |
Creating a blunt trailing edge from sharp trailing edge
Rep Power: 14 |
Hi all,
Just a quick question. I need to edit the point geometry of the NREL s809 wind turbine blade such that it will have a (small) blunt trailing edge instead of a sharp one in order to model vortex shedding at really high angle of attack. Having a sharp TE also constantly interferes with the meshing. I have tried to cut it using autocad but have run into problems trying to export the point data afterwards. Attempts to simply edit the point data such that the TE is blunted have also failed to produce useable results. Is there a better and more accurate way to do this? Any help would be greatly appreciated. Thanks! EDIT: Noticed a mistake in the title. I meant creating a blunt trailing edge from collapsed TRAILING edge...not leading. Apologies Last edited by gmd; March 2, 2012 at 11:39. Reason: mistake in title |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Y-Plus values at aerofoil leading edge and trailing edge at high incidence | Engr07 | Main CFD Forum | 4 | June 29, 2012 10:42 |
[ICEM] Hole near sharp trailing edge of airplane/wing geometry | jlichtwa | ANSYS Meshing & Geometry | 2 | September 21, 2010 15:19 |
Which trailing edge is correct for meshing of aerofoils for CFX | LSC | CFX | 0 | May 10, 2009 12:45 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
