[ICEM] problem in periodic
Old   March 20, 2012, 19:34
Default problem in periodic
mohamed khedr emam
m5edr is on a distinguished road
I am used rotational periodic option
everything seems ok but after doing "mesh check" , a massage appear like
"shell 101273 has node 1177 which has no twin" and then a subset of 300 error is created "image 1"
I think the error in the surface of perioidc due to it contains two surface inside each surface of periodic image 2
Or may be the error that the presnt of curves in small surface in periodic "image3"
Anyway I don't know
I used 3D unstructured mesh "octree"
Any suggestion pls?
thanks
m5edr is offline   Reply With Quote
Old   March 21, 2012, 09:46
mohamed khedr emam
Any idea
Old   March 21, 2012, 10:31
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
The Periodic check is between parts... So it doesn't necessarily mean that the node has no twin, but rather that the node has no twin in the other part you selected. This can happen quite easily in an otherwise periodic mesh if the curves are in other part names.
For instance, the twin for the node in part PER1 may be in the CURVES part on the other side...
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   March 21, 2012, 11:20
mohamed khedr emam
Thanks Simon for your effort
o.k, i created parts before>> PER1 contains (2 surfaces) and PER2 contains the two surfaces (same surfaces in PER1)
but i don't understand>>> you mean i leave it as it is
when i send the mesh to fluent no error occur until i do a "check" , fluent warning me from the periodic faces(that in ICEM check)
Old   March 21, 2012, 12:35
PSYMN's Avatar
Simon Pereira
Even if Per1 and Per2 only contain surfaces, the nodes on the edge of those surface could be assigned to the curves, points or surface parts. The safest bet is to make sure that the curves along the edge are in the parts you are checking...
But before you do that, create a subset using the node number or location that the error gave you... Then do a visual sanity check to see where that node is... If it is not on a curve, then perhaps you have some other issue.
Old   March 21, 2012, 16:44
mohamed khedr emam
Now , i'm select the right periodic faces (during "check mesh") and different massage from "check mesh window" appear:
(292 problems were found for Multiple edges)
and then create a subset (image) it the same node BUT the massge different (NOT told me" shell has node which has no twin )
Is this GOOD?
I read in other "Forums" it is not important to have "Multiple edges"
Thanks
Old   March 21, 2012, 17:04
PSYMN's Avatar
Simon Pereira
Right, so you are not getting the periodic problems message anymore.
This new issue (multiple edges) is something else. You just need to take a look and make sure those multiple edges are where they should be (at expected T connections...)
It looks right from here...
Periodic boundary condition Arif FLUENT 3 March 9, 2017 01:18
3Dimensional periodic boundary condition bench mark problem for incompressible HaKu Main CFD Forum 0 September 7, 2011 13:48
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
periodic flow problem Alok Gupta FLUENT 1 November 19, 2003 07:05
