[GAMBIT] Gambit - Problem having shadow wall on volume |
March 21, 2012, 19:53 |
Edward Overy Jr.
Rep Power: 14 |
I've constructed a 3d file in gambit to model heat and mass transfer from a leaf. I have a rectangular volume made and i made a volume inside the rectangular volume to be the leaf.
After meshing the inside the leaf volume with hex/wedge cooper and the rectangular volume using hex map, specifying the zones and exporting it to fluent, under boundary conditions, there is just leaf, there is no leaf_surface which I need for some user defined functions. What do I need to change in gambit so that I can get the leaf to have the leaf shadow as well? |
March 22, 2012, 06:51 |
Maxime Perelli
Rep Power: 41 |
you need to split or substract.
Post a picture or a sketch
In memory of my friend Hervé: CFD engineer & freerider |
March 22, 2012, 15:19 |
Edward Overy Jr.
Rep Power: 14 |
http://imageshack.us/photo/my-images/138/leaf3d2.png/
There's the picture of the gambit file before I meshed bot the inside of the leaf volume and then the overall volume. I tried subtracting the leaf volume from the rectangular volume, but then it won't mesh using the same hex method. |
March 23, 2012, 01:30 |
Maxime Perelli
Rep Power: 41 |
ok then if you substract the leaf from the rectangular volume, and you cannot mesh the volume with hex anymore, that means you are on the right way.
Thus you cannot mesh non-basic volume with hex automatically. You need to split your volume, into smaller volumes, which will be hex- meshable
gambit, mesh, problem, shadow, wall |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Having problem in creating a volume mech in GAMBIT | Jake | FLUENT | 1 | April 25, 2008 05:01 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 20, 2006 23:31 |
