[ICEM] Model size inconsistency between DesignModeler and Icem
Old   April 12, 2012, 08:55
Default Model size inconsistency between DesignModeler and Icem
Kristin_N is on a distinguished road
I have encountered a problem with my geometry's dimensions not staying consistent between the Ansys Design Modeler and Icem CFD and I wonder if anyone has any idea on how to avoid this problem (or fix it)?
If I draw a cylinder in the Design Modeler with a diameter of 0.01537m for example, when I check it in Icem the new diameter is 0.0153592m and when I save the mesh as .cgns this is the dimension that the cfd code is reading (both Flluent and an industrial code). I even tried drawing it with units of mm and then converting it to m in Icem when I import the geometry using "Workbench Readers", but it doesn't change anything. I think the issue lies with Icem though, as even if I draw the cylinder directly in Icem using points, curves and surfaces the output coordinates aren't exactly the same as what I input. This inconsistency did not happen when I tried using 0.025m for the diameter, but my method was the same, so I don't understand where the problem is.
Since I need to use a diameter of 0.01537 exactly though, I would really appreciate any suggestions on how to maintain the correct dimensions all the way from drawing the model, to meshing it and to inputting it in the code.
Thank you,
Kristin
Kristin_N is offline   Reply With Quote
[ANSYS Meshing] Difference between DesignModeler and ICEM CFD matteogir ANSYS Meshing & Geometry 5 January 24, 2012 15:02
Importing Model from DesignModeler into ICEM Josh ANSYS Meshing & Geometry 10 March 9, 2010 16:09
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 03:39
ICEM 10 - Defining inlets DAK565656 CFX 0 November 4, 2006 05:31
ICEM CFD 5.1 Hex-Tet mesh merging failure bogesz CFX 1 January 29, 2005 06:46
