[ICEM] Cylinder meshing tutorial
Like Tree8Likes
Old   April 2, 2012, 09:40
Default Cylinder meshing tutorial
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
This is two part video tutorial on "how to create high quality meshing around circular cylinder in ICEM"
Same problem is also discussed here.
http://www.cfd-online.com/Forums/ans...cylinders.html
rajann_786 and aero_head like this.
Far is offline   Reply With Quote
Old   April 2, 2012, 11:02
Default Part 3
Far
Sijal
Part III is uploaded here http://www.youtube.com/watch?v=UgEKo...ature=youtu.be
Part I is further subdivided into 2 smaller parts as youtube doesn't allow me to upload files with duration more than 10 minutes (Originally part I was 17 min clip)
Uploading part I and II shortly.
aero_head likes this.
Old   April 2, 2012, 15:20
Default Part 1 & 2
Far
Sijal
Part I http://www.youtube.com/watch?v=T2Dxa...ature=youtu.be
Part II http://www.youtube.com/watch?v=CYz3H...ature=youtu.be
Old   April 2, 2012, 15:28
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
What software did you use for recoding ?? what is your pc spec ??
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   April 2, 2012, 15:38
Far
Sijal
camtasia http://www.techsmith.com/camtasia.html
PC specs : Dell 670 precision 3.6 GHZ dual CPU Quad core 4 GM RAM
Old   April 2, 2012, 15:41
diamondx's Avatar
Ghazlani M. Ali
ok i was using same but couldn't come up with videos like that !! it's because of the specs
Regards,
Ali
Old   April 2, 2012, 15:42
Far
Sijal
Ya, lower the specs higher the quality
diamondx and aero_head like this.
Old   April 9, 2012, 04:32
Mahindra
mahi007 is an unknown quantity at this point
Hello Far
Can you just explain me how to extrude the mesh into a 3D one and necessary changes to the parts and boundary conditions?
Please its urgent. I have to meet my project deadline.
Thanks
mahi007 is offline   Reply With Quote
Old   April 9, 2012, 11:57
Far
Sijal
OK Here it is.
Old   April 9, 2012, 17:25
Far
Sijal
Old   April 10, 2012, 02:02
Mahindra
Hello far
I am trying to extrude the mesh you had uploaded long ago. It can be obtained from
http://www.4shared.com/rar/LRL3929E/..._complete.html
When I extrude that mesh with 4 layers with a uniform spacing of 1, I am getting error in FLUENT while reading mesh. The error is about the interior circle which you made to capture boundary layer effects with a finer mesh. Kindly please let me know how to make that into 3D mesh as soon as possible.
Thanks
Mahindra
Old   April 10, 2012, 03:05
Far
Sijal
Use the files posted in this thread (post #1).
Old   April 10, 2012, 06:39
Mahindra
Sorry I did not get you. What to do with those files?
Can you please tell me what is going wrong when trying to extrude that mesh you have made?
Please its urgent.
Thanks
Old   April 10, 2012, 08:31
Far
Sijal
I have attached new cylinder meshing files in this thread at post #1. I have used those files and found no problem.
Old   April 10, 2012, 10:24
Mahindra
I am trying to compare simulation results for both 2D and 3D at certain regimes to show disturbances. I cannot use a different mesh now to do 3D analysis. The mesh you provided works fine in 3D also as you have told me earlier. Please find some time to give me some advice by working on that mesh.
Thanks
Old   April 10, 2012, 14:05
Default special case of cylinder-cylinder connection
  #16
Sören
despaired student is on a distinguished road
do you know how to mesh the connection between two cylinders properly when one small cylinder is perpendicular connected to a bigger one at the top/bottom. (picture 1 +2)
I always have bad elements where the small cylinder meets the ceiling of the bigger cylinder. (picture 3)
Is there a good way to make the connection without these bad elements or are they unavoidable respectively of low importance?
kind regards
File Type: zip Testzylinder-3.60-Test eines installierten Grenzbereichs - O-Grid ausbessern.tin.zip (39.0 KB, 38 views)
File Type: zip Testzylinder-3.60-Test eines installierten Grenzbereichs - O-Grid ausbessern.blk.zip (35.8 KB, 25 views)
despaired student is offline   Reply With Quote
Old   April 10, 2012, 14:09
Sören
this picture is better than the above picture 3.
Old   April 11, 2012, 08:03
Mahindra
I could extrude the mesh you provided me earlier in http://www.4shared.com/rar/LRL3929E/..._complete.html
But the problem is in the interior circle while reading in FLUENT. Please look into the problem once and give me a solution. Please!!!!!!!!!
Old   April 11, 2012, 08:07
Far
Sijal
Delete the interior circle curves before extruding and use link edge command to make the edges of circular shape.
This procedure is defined in part I.
Old   April 11, 2012, 08:28
Mahindra
How does the mesh in two regions merge after deleting interior circle?
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
Structured meshing of a cylinder in ICEM vmlxb6 ANSYS Meshing & Geometry 4 October 19, 2010 17:45
Structured meshing of a cylinder in ICEM vmlxb6 ANSYS Meshing & Geometry 0 October 9, 2010 22:56
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 21, 2006 00:31
Meshing spheres in a cylinder Jesse FLUENT 3 November 23, 2005 22:03
