How to apply a "Heat Flux" boundary condition on a vertex in ANSYS Workbench |
May 13, 2012, 11:53 |
Rep Power: 14 |
I want to solve in Workbench a 1D problem of heat conduction. In the same way that I am able to apply a "Force" boundary condition on a vertex in the structural analysis, I want to apply a "Heat Flux" on a vertex in the thermal analysis (the equivalent to a force in the structural study), but I cannot do it from the "Mechanical" application. I am only able to impose a "Temperature" or "Heat Flow" boundary condition on a vertex. Any clue about it? Isn't it possible to solve a 1D problem of thermal analysis as I can do it for the structural part?
My geometry is composed of lines that have assigned a circular cross-section. |
May 14, 2012, 16:14 |
Rep Power: 14 |
Solved it. In this case it's just applying a "Heat Flow" boundary condition (imposing a heat source) on a vertex, whose value is computed from the definition: Heat Flux = Q/A, where A is the cross-sectional area of the truss and Q is the heat source.
ansys workbench, heat flux, steady state thermal |
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 09:23 |
mixed inflow/outflow downstream boundary condition question | peob | OpenFOAM Running, Solving & CFD | 3 | February 3, 2017 10:54 |
Mixed/Robin boundary condition | aaev | OpenFOAM Bugs | 2 | December 15, 2011 14:03 |
Apply boundary condition in sph(smoothe particle hydrodynamic) method | maasoumihashem | Main CFD Forum | 1 | July 29, 2010 06:22 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
