June 17, 2012, 05:48 |
Steel tube filled with concrete
Ivan
Hello all,
I am trying to model axially compresed composite column made of steel tube filled with concrete, but since I am novice in Ansys, there are many problems (and so little time to solve them). So far i have manage to create geometry using next commands: /prep7 rectng,0,75,0,300 !! for concrete core (150mm diameter, 300mm high) rectng,75,80,0,300 !! for steel tube (160mm diameter, 5mm thick wall, 300mm high) Next: k,1001,0,0,0 k,1002,0,300,0 Moddeling/Operate/extrude/areas/about axis !! with this I get cilinder and tube Define element type ET,1,solid 65 !!for concrete ET,2,shel181 !! for steel And that is about it. 1.How to assign ET to cilinder to be solid65 and tube to be shell181? 2. What MP to assign to these element, since I am planning to do nonlinear analysis? 3.I have seen in one example TB command with a lot of numbers following, but cannot find what they mean. 4. how to add incrementally load to the upper surface? Pls. help Best regards |
problem in toposet | Ahmed Khattab | OpenFOAM Pre-Processing | 27 | March 3, 2023 21:12 |
HLL Riemann Shock Tube Matlab Problem | Luke F | Main CFD Forum | 2 | May 20, 2016 02:10 |
What is best mesh for cylinder tube? | olivia | FLUENT | 7 | January 16, 2014 05:55 |
Hydraucone Draft Tube CFD | tojoe999 | OpenFOAM | 0 | March 5, 2012 13:10 |
Argon gas inside a steel tube? | rskrishna87 | CFX | 3 | April 27, 2011 19:26 |
