Home > Forums > Software User Forums > ANSYS
Mesh transition (volume) in a cylinder
Old   August 27, 2012, 09:28
Default Mesh transition (volume) in a cylinder
PBruschi is on a distinguished road
Hi.
I'm meshing the volume of a cylinder and i have a problem. The tetra sizes should not be uniform in all the cylinder. I need to make a transition, so it must grow the size as the mesh goes to the perifery. Summarizing, in the very interior of the cylinder, the mesh must be more refinated. The problem I have is that the size transition is too abrupt, i need to make it more softly. What configuration should I change?
Thank you very much.
PBruschi is offline   Reply With Quote
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
