Fluid Structure Interaction Problem
Like Tree2Likes
  • 1 Post By meb
  • 1 Post By bkrdnr
Old   November 29, 2012, 02:55
Default Fluid Structure Interaction Problem
bkrdnr is on a distinguished road
Hi!
I am working on a FSI problem. I use Numeca Fine/Turbo and Ansys for the simulation. I have mapped the cfd pressure data and import it to the Ansys. I want to check if the mapped cfd data and the meshes are matching properly. Could you please recommend me a way to compare these two?
Best Regards,
Bekir
bkrdnr is offline   Reply With Quote
Old   December 4, 2012, 14:21
Default Check Resultant
meb
Marco Evangelos Biancolini
meb is on a distinguished road
Originally Posted by bkrdnr View Post
Hi!
Best Regards,
Bekir
Check if the resultant load is the same. This should be available both in CFD and structural solver. Usually meshes are not conformal and resultant load is the first quantity to observe to understand the job of the interpolator.
I have successfully used FSI mapping of Fluent (to map Fluent results onto Nastran FEM mesh). It works fine, but normals are to be properly oriented, check them carefully!
bkrdnr likes this.
meb is offline   Reply With Quote
Old   January 15, 2013, 08:13
Thank you Marco!
meb likes this.
Fluid Structure Interaction Joh CFX 4 September 18, 2012 08:47
Fluid Structure Interaction Apollo Main CFD Forum 5 July 4, 2011 16:15
Fluid Structure Interaction problem for airfoil vinair39 OpenFOAM 0 February 8, 2011 07:57
fluid structure interaction taru agrawal FLUENT 4 September 10, 2007 03:12
FLUID STRUCTURE INTERACTION Javier Main CFD Forum 5 October 11, 2004 04:22
