January 4, 2023, 08:24 |
Ansys aqwa convolution error
MAI THI LOAN
Rep Power: 6 |
Hello everyone,
I am simulating the mooring line with the fish farm system. During the simulation of the mooring line in irregular waves with irregular wave response. However, I got the error "CONVOLUTION ERROR. The convolution has failed to calculate a satisfactory fit to the added mass/damping for the structure. This is usually caused by insufficient frequencies or an inadequate frequency range. PLEASE-ENSURE THAT THESE ARE SUFFICIENT "BEFORE" contacting user support. Frequency range for structure should be at least 0.247 to 5.695 rad/sec" I tried to simulate the system with a range frequency from 0.2 to 0.6 rad/s. But the error still occurred. I hope to receive a solution from everyone. Thank you so much in advance. |
March 26, 2023, 14:06 |
Joshua Cutler
Hi mailoan2306,
Did you manage to find a solution to this problem? Kind regards |
Display Modes | |
[swak4Foam] swak4foam openfoam 7 installation problem | Andrea23 | OpenFOAM Community Contributions | 1 | February 17, 2020 19:11 |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 01:21 |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 08:43 |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 07:25 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 06:07 |
