Ansys 14 on Ubuntu 12.04
Old   September 16, 2012, 10:46
Exclamation Ansys 14 on Ubuntu 12.04
Mariano
MarTar is on a distinguished road
Hy all,
i have installed Ansys 14 on Ubuntu 12.04 precise 64 bit.
I had no problem with installation, but i can not complete the procedure for the correct specification of the license file. In few words, when i indicate the license file, the license manager returns the message that the FLEXID in the license file does not correspond to the one of the system. Indeed, when i visualize the FLEXID by means of the license manager utility i find a series of zeros. According to my experience, this is might be caused by the LSM package, but i have it installed on my machine.
May be the cause of this problem the installastion directory? I installed Ansys into my home directory, not into the default directory /usr.
Morevover, may be the cause the libXm.so library? I do not have it: how can i install it?
Many many questions....I hope in your support!
MarTar is offline   Reply With Quote
Old   September 17, 2012, 03:05
Mariano
Anyone can help me?
Old   October 2, 2012, 11:41
Dogan
epilson is on a distinguished road
did you use -no root commant on starting of the ANSYS.
As I know ANSYS require to setup in /usr
epilson is offline   Reply With Quote
Old   October 2, 2012, 12:09
Mariano
I try to open the license manager both as root and stardard user: in any case, i always get a serie of zero when i visualize the machine hostid of my pc, via the license manager.
This is a critical issue because the licecense manager does not recognize the host id in the license file: so can not open any program of Ansys Workbench.
Anyway, thanks for answering!
Old   October 2, 2012, 19:11
Dogan
you have to use
sudo ./INSTALL -noroot
command to install the ANSYS. After you will use LM.
Old   October 6, 2012, 12:58
Mariano
Originally Posted by epilson View Post
you have to use
Can you explain me in some details the installinf procedure?
Which commands i have to use ? I know i must be root during installation of Ansys and License Manager; the i change the ownership of the various ansys folders.
My problem is: FLELXlm does non start.....
Anyway, thaks for your previous answers!
Old   October 6, 2012, 12:59
Mariano
...sorry for my english! i wrote too fast!!
Old   October 19, 2012, 09:31
HMN
HMN is on a distinguished road
Hola Mariano,
I think you should repeat the whole intallation process like somebody said: sudo ./INSTALL -noroot
You can't start FLELXlm because it wasn't probably properly installed.
Try it again and let us know what happens. Ansys is only tested to work in Suse and Red Hat teorically, but I am planning to install it in Ubuntu too.
HMN is offline   Reply With Quote
Old   October 19, 2012, 09:34
HMN
By the way Ubuntu 12.10 came out yesterday. I am planning to install it in some days, and ansys on it.
Old   October 28, 2012, 07:04
Mariano
Originally Posted by HMN View Post
Hola Mariano,
I have just tried to install ansys and license manager with the command suugested by you, but the problems still persists.
Meanwhile i found a problem with flexlm: probably the flexid of my pc is not recognized because the installation of flexlm, during ansys installation, has not been completed properly....I don't know how to solve the problem!!
Old   March 2, 2013, 00:29
Red face
  #11
Dmitry
imnull is on a distinguished road
u will need to install Linux Standard Base (lsb)
imnull is offline   Reply With Quote
Errors while installing openfoam on ubuntu 12.04 AND 11.10 fshak92 OpenFOAM Installation 27 May 1, 2021 12:10
Installation on Ubuntu 12.04 LTS samiam1000 OpenFOAM Installation 11 May 26, 2012 05:54
Openfoam 2.1 installation in ubuntu 12.04 jsm OpenFOAM Installation 11 May 7, 2012 04:56
Ansys 13 - License problem on Ubuntu MarTar ANSYS 4 February 3, 2012 02:13
Ansys 13 64 bit Linux (ubuntu) licencing epilson ANSYS 4 December 16, 2011 03:15
