Multiple Thermal Conductivity for a Material at different temperature |
April 17, 2013, 20:24 |
AJ Hunter
Rep Power: 13 |
I am trying to create a material in ANSYS that has a different thermal conductivity at different temperatures. I tried the following:
Creating a function "Function 1" with my data: -Argument Units: K -Output Units : W m^-1 K^-1 Creating an expression "Expression 1" linked to the function: -Expression 1= Function 1(K) This gives me the following error: Bad expression value 'Expression 1' detected in parameter 'Thermal Conductivity' in object '/LIBRARY/MATERIAL:Zirconium/PROPERTIES/THERMAL CONDUCTIVITY'. CEL error: The following unrecognised name was referenced: K. Which basically says that I can't use K as the input to my function? |
April 18, 2013, 02:59 |
#2 | |
Rep Power: 13 |
from the info you have given, it seems that you have tried to modify an element's properties from the MATERIALs library. Something is wrong with you re-definition. Could you provide additional info - what module of ANSYS do you use? Possible solutions for the definition of temperature dependence of thermal conductivity: 1. if you use Transient module, you can specify temperature dependence of thermal conductivity in a Table form in the section 'Engineering Data'. 2. if you use FLUENT module, you can define a User-Defined Function (code it in C) and either compile or interpret it, and then use this function in material's properties specification. (There is a reference guide on how to make the User-Defined Functions in FLUENT). regards, |
April 20, 2013, 10:15 |
Derek Lastiwka
Rep Power: 16 |
This looks like it is in CFX. Try putting square brackets around K. Like this:
[K]
Derek Lastiwka Mechanical & Fluids Engineer dlastiwka@graymattereng.com Gray Matter Engineering Inc. |
interpolation data, thermal conductivity, user material |
Problems with CEL (guess it's simple to solve) | Felggv | CFX | 22 | March 26, 2019 16:42 |
Thermal conductivity UDF | jack.s | Fluent UDF and Scheme Programming | 4 | February 29, 2012 11:57 |
Multiple domain/Multiple material problems... possible or not? | Amiga500 | OpenFOAM | 1 | April 14, 2010 15:32 |
Inteface thermal conductivity | ado | Main CFD Forum | 4 | March 11, 2002 19:46 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
