January 27, 2017, 09:54 |
Different moment between Fluent and CFD post
Robert
Rep Power: 9 |
I am running simulations on a rushton turbine at Re=200. In this regime, the Power number should be Po~3.5. Po is calculated from the torque obtained in the simulation. However, when I calculate the torque (moment) on the impeller in fluent, the value is off, resulting in Po~6. When I calculate torque on the impeller in CFD post, I do in fact get the right value, resulting in Po~3.5. Does anyone know what can cause this difference, because I would expect both outcomes to be the same. Any comment would be appreciated. Thanks |
July 7, 2021, 11:51 |
Cledson
Hi Falldox
I experienced the same problem, getting values in CFD Post of something about 60% of the values in Fluent. After some look I noticed that in Fluent I was evaluating the variable Moment Coefficient and not the variable Moment. After this correction I got similar values. This could be your case. |
cfd post, fluent, moment, torque |
plot Cp over curved line in bend wall using fluent or cfd post | hesham | Visualization & Post-Processing | 1 | September 7, 2022 08:07 |
Fluent export - CFD Post - Airfoil Results | Wingman | ANSYS | 0 | November 18, 2016 16:36 |
Error while reading CFD Post file exported from FLUENT | amjadfirst | FLUENT | 0 | September 3, 2016 19:25 |
Post processing in CFD Post or Fluent. | Blobs | OpenFOAM Post-Processing | 2 | June 26, 2016 07:23 |
Separate Convective and Radiative heat transfer in CFD post using fluent as a solver | Lemanes | FLUENT | 1 | July 6, 2015 10:31 |
