April 20, 2013, 05:51 |
Mach Number in CFD-Post
Esteban
Rep Power: 13 |
Hi everyone,
I work on modeling of supersonic flows and I analyse the results with CFD-Post. (I work with a density based solver and ideal gas.) Someone knows why I can not find mach number in the proposed list of contour? Thanks Valio |
April 20, 2013, 10:09 |
Derek Lastiwka
Rep Power: 16 |
Can you send me you files? I can take a look and see.
Derek Lastiwka Mechanical & Fluids Engineer dlastiwka@graymattereng.com Gray Matter Engineering Inc. |
April 23, 2013, 10:14 |
Derek Lastiwka
Rep Power: 16 |
Open your file in Fluent (both cas and dat files). Then go file>export to CFD-post (you will need to set the reference pressure to something other than 0). Pick the variable you want to export and type in a file name. Open this new file in CFD-post and you should have all the variables you picked available in CFD-post including Mach number.
Display Modes | |
ERROR #001100279 has occurred in subroutine ErrAction. | smnaryal | CFX | 11 | December 20, 2017 16:32 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
Problem with decomposePar tool | vinz | OpenFOAM Pre-Processing | 18 | January 26, 2011 02:17 |
Mach number | Singh | Main CFD Forum | 0 | July 2, 2008 09:51 |
non-dimensional analysis in Fluent | Endee | FLUENT | 8 | September 7, 2005 16:16 |
