[POLYFLOW] How to define VOF initial fluid fraction? |
June 13, 2011, 18:57 |
Bin
I want to test a simple 2D VOF model in POLYFLOW. The gravity-driven fluid flow starts from a certain initial shape (e.g. a cap) in a 2D cavity. The only options to define this intial condition in POLYFLOW are under 'initial fluid fraction':
1. map from CSV (Excel) file 2. user defined function I don't know why 'user defined function' is not available (grey). Anybody here has tried the CSV file for these kind of problems? I think POLYFLOW's VOF model is not well developed. Because there is no VOF setting for each subdomain. VOF is just simply coupled with the whole domain. |
December 25, 2012, 04:50 |
bruce
Rep Power: 13 |
Hi cutejerk,
I met the same problem as yours. I tried to use ANSYSPPOLYFLOW 14.0 to do some simulations with VOF model, but I donot know how to patch a initial fluid as a cylinder shape. have you resolved your problem? Thank you in advance. |
January 2, 2013, 05:10 |
#3 | |
Yanlong Li
Rep Power: 13 |
I am learning UDF (user define funciton), I just saw an UDF was set for your situlation as well as its exmple. I forgot it, It's about DEFINE_INITILE or DEFINE_INTE, some thing like that. OR, if your shape is just a cylinder, you can just use " Adapt->Region" to define a register of cylinder, then patch the initial value in this register. hope it can help you. Long |
January 2, 2013, 08:19 |
#4 | |
bruce
Rep Power: 13 |
I think "adapt"thing you said is about ANSYSFLUENT not POLYFLOW. As I can't find the "adapt"tab in polyflow but Fluent. I guess you are learing UDF of Fluent. Right? Thank you all the same. |
January 2, 2013, 09:32 |
Yanlong Li
Rep Power: 13 |
February 22, 2013, 02:58 |
Zhiyong Wang
Rep Power: 14 |
DEAR, You are right, VOF in polyflow is not so good now, and the initial function in not so powerfull as that in Fluent.
Not the same with you,there five ways to initial under "Initial Fluid Fraction" in my project, namely Constant, Linear function, Multi-ramp, CSV and UDF. In my project , Multi-ramp is OK. I know nothing about CSV. My UDF option is also grey, I think the reason is there are no UDF in your Polyflow. Think about the usage of UDF in Fluent... wzy_me@163.com, just e-mail me |
June 6, 2013, 03:42 |
#7 | |
bruce
Rep Power: 13 |
June 6, 2013, 08:47 |
Zhiyong Wang
Rep Power: 14 |
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 06:54 |
icoLagrangianFoam OF1.6 myNewParticleSolver | heavy_user | OpenFOAM | 23 | June 2, 2020 02:18 |
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 04:13 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 05:55 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
