IC Engine Exhaust Port Flow
Old   July 5, 2013, 02:02
Default IC Engine Exhaust Port Flow
Reece
Ospi is on a distinguished road
I am in the process of performing port flow analysis and have successfully run inlet flow analysis however I am having issues with running an exhaust port analysis due to the ICE being seemingly set up for inlet only. I wish to completely block the inlet port and do an exhaust flow with the cylinder itself being the inlet to the port and the exhaust header flange being the outlet. Even when I set the inlet/outlet like this the software still treats the cylinder body as part of the outlet plenum and thus fails. Is there a simple way to run the exhaust port analysis or is it a case of dismantling the ICE port flow setup to suit this reversed flow situation?
Ospi is offline   Reply With Quote
Old   July 10, 2013, 22:59
Reece
not to worry.
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 17:02
Non-steady flow simplified for use in Vissim steamerandy Main CFD Forum 0 October 31, 2011 21:08
Engine manifold flow stephen_devaux Main CFD Forum 2 July 21, 2011 02:54
flow through an engine cylinder TOM FLUENT 2 December 20, 2001 04:25
IC Engine Flow simulation Apurv Main CFD Forum 2 February 8, 2000 00:12
