August 14, 2013, 16:15 |
HELP; Ansys 13.0 Combustion Problem!
Clan McKenzie
Rep Power: 12 |
Hello Everyone!
I desperately need assistance with the following problem. I have been trying to do combustion analysis for a couple of months now and have a repeating problem. During the solution portion of the simulation on FLUENT 13.0 I have the following read out on each time step... "Minimum PDF table temperature in 9893 cells on zone 3" The number of cells fluctuates greatly. I have a video of each step that I have done at the link below. https://www.youtube.com/watch?v=-CDNB22fWFo I have tried increasing the mesh, increasing the fuel and oxid temperatures without any results DISREGARD THE FLOW RATES IN THE VIDEO! I have corrected them and they are not connected to the error. THANK YOU IN ADVANCE! |
August 14, 2013, 17:16 |
Clan McKenzie
Rep Power: 12 |
Thank you so much for your speedy response!
I just realized where the TUI interface is on Fluent 13.0. Right smack in front of me! I will try it and get back to you. Again I greatly appreciate your help |
August 14, 2013, 17:54 |
Clan McKenzie
Rep Power: 12 |
Well I have tried to find the option for the Maximum Heat Loss Fraction and have not been able to find it. The following is as far as I got through the TUI command window. If anyone can help I would GREATLY appreciate it!
> adapt/ file/ report/ close-fluent mesh/ solve/ define/ parallel/ surface/ display/ plot/ views/ > define /define> beta-feature-access materials/ profiles/ boundary-conditions/ mesh-interfaces/ solution-strategy/ custom-field-functions/ mixing-planes/ turbo/ dynamic-mesh/ models/ units enable-mesh-morpher-optimizer? operating-conditions/ user-defined/ injections/ parameters/ /define> models /define/models> acoustics/ heat-exchanger/ steady? addon-module multiphase/ unsteady-1st-order? crevice-model? radiation/ unsteady-2nd-order-bounded? dpm/ solidification-melting? unsteady-2nd-order? energy? solver/ viscous/ eulerian-wallfilm/ species/ /define/models> species /define/models/species> diffusion-energy-source? off? thermal-diffusion? inlet-diffusion? save-gradients? volumetric-reactions? multicomponent-diffusion? species-transport? /define/models/species> |
August 16, 2013, 17:40 |
Clan McKenzie
Rep Power: 12 |
Thanks for all the replies. I was finally able to find the location where I could lower the Maximum Heat Loss Fraction! You were correct it is under "non-premixed-combustion-expert". Originally it was set to 0.66, I set it to 0.4 and ran the simulation again. Unfortunately this did not help fix the error. I still have "minimum pdf table temp" error occuring on every iteration and to many cells. I have also tried reducing the under relaxation factor for Energy to 0.6 and this did not help either. I have increased the mesh as well as increased the inlet temperature to 600K for the fuel and the oxide to no avail. I have noticed that my P1 residuals are acting strangely though. They are far below the other residuals. Any thoughts? |
combustion, fluent 13.0, pdf-mixture |
[DesignModeler] ANSYS 13 - DesignModeler sketching problem | Novosiberian | ANSYS Meshing & Geometry | 6 | June 27, 2014 11:38 |
Oil combustion problem | brajh11 | CFX | 1 | December 7, 2012 02:49 |
Problem of Ansys for machanical a element or a group of elements | lovelyeverything | ANSYS | 0 | April 18, 2012 23:54 |
[ANSYS Meshing] Import ".dbs" into Ansys 13.0 | antallo | ANSYS Meshing & Geometry | 2 | February 17, 2011 14:33 |
ANSYS 13 problem | zona | ANSYS | 0 | December 16, 2010 07:48 |
