March 26, 2010, 19:53 |
Parameters and Fluent in Ansys 12
Edu
Rep Power: 16 |
Hi all!
I´m doing a rear wing with the new Ansys 12, and I need to simulate some variations of the flap (angle of attack and it´s position from the main airfoil). I put these values as parameters in the modeler, and now I would like to know if I can automate the simulations and get the Cl and Cd of each simulation. I want to do a table with all the combinations and their respective Cl and Cd to choose most optimized version. The dimensions are defined as Input Parameters. ¿How can I define an output parameter? Thanks in advance! Regards: -Edu- |
March 29, 2010, 15:43 |
Edu
Rep Power: 16 |
Has somebody an idea?
October 21, 2010, 12:13 |
Rep Power: 17 |
In CFD-Post, click on Expressions tab, right click on the expression and select Use as Workbench Output Parameter.
October 24, 2010, 12:51 |
Edu
Rep Power: 16 |
Hi Jade!
Thanks for your answer, but I did it some months ago, and it worked perfectly. Regards: -Edu- |
March 21, 2014, 10:57 |
Chandrasekhar
Rep Power: 12 |
Hi
i would like to change the boundary condition (i.e the heat flux at a wall) by 50 units each time and run the case till it converges. right now i am using the modification tool in fluent but i would like to know how to write it as a parameter and use it to define the boundary condition at the wall. Any help on this would be appreciated. Many thanks for replying. with regards |
Display Modes | |
Integration of a Custom C++ Model into FLUENT | Syed Haider | FLUENT | 2 | March 6, 2018 23:37 |
Reverse rate parameters with CHEMKIN imports | Kevin L | FLUENT | 1 | June 27, 2013 04:22 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 13:43 |
Fluent parameters for sailing yacht analysis | Daniel | FLUENT | 0 | April 24, 2007 06:47 |
Some nondimensinal Parameters | American Larki | FLUENT | 0 | December 21, 2002 18:39 |
