May 3, 2014, 23:59 |
ICE Problems
Cy
I am quite new to Ansys so I am not really aware of how to determine what is wrong. I am trying to run an IC analysis with an imported part from Solidworks. I am trying to use the Input Manager function, but I cannot seem to get the valve seat correct. I have tried to follow the ICE tutorials from Ansys with no luck. I tried just using a cross section of the model, but that did not help much. The part will just not decompose properly (From the tutorial, I would imagine that this is vital). Since, the geometry is not correct, I cannot get the part to mesh. Any help would be appreciated. I have attached a Solidworks complete model and a cross section. Any guidance would be greatly appreciated. Thanks. |
May 5, 2014, 10:33 |
Jacob Twat
I had the same problem with file from Inventor. In my case solution was to export my geometry file to .igs, and everything works fine. |
Display Modes | |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[mesh manipulation] Problems with rotational cyclic boundaries | TReviol | OpenFOAM Meshing & Mesh Conversion | 8 | July 11, 2014 03:45 |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 12:13 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 05:44 |
Help required to solve Hydraulic related problems | aero | CFX | 0 | October 30, 2006 11:00 |
