June 1, 2014, 19:43 |
2d rans fluent
AK
Rep Power: 13 |
I need to simulate an under-expanded axisymmetric jet of NPR 3.67 from a CD nozzle. My design Mach number is 1.00 and my jet Mach number is 1.5. I wanted to know about implementing the boundary conditions on FLUENT.
My model is symmetric about x axis. I have used far-field boundary conditions with 101325 Pa and 0.001 Mach as the values on the upper and leftmost parts of the domain. I have used outflow on the rightmost part with 101325 Pa. My nozzle is modelled only from after the throat. At my velocity inlet boundary condition, how do I make sure my NPR is 3.67 so that my jet expands to 1.5? What should the values Velocity Magnitude, Supersonic/Initial Guage Pressure , and Outflow Gauge Pressure be? I have set my operating pressure as 0. Please help |
boundary conditions, fluent 14.5, jet flow |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 03:34 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 06:22 |
Alias problem when starting FLUENT from command line | batch_error | FLUENT | 0 | May 24, 2012 08:20 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 02:44 |
