August 13, 2016, 20:09 |
How to match the Reynolds number in CFX ?
Tommy Chen
Rep Power: 15 |
Hi I got a problem while using ANSYS CFX , the case I'm going to run is an aircraft cruising at 10 km high with mach=0.75. Usually when I was doing with the CFD code like SU2 or the inhouse code of our lab, I could easily set the reynolds number to be a certain value. Reynolds number is one of the three similarity parameters, with the other two as mach number and the scaled shape.
However, in CFX, is there a way for me to directly set the Reynolds number that could match the case ? If not, I guess I have to change the gas property to indirectly tune the Renolds number, then how could I do it ? |
Display Modes | |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
How to define the Reynolds Number in CFX? | yflin | CFX | 27 | November 24, 2018 04:20 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
Reynolds number error - CFX | saisanthoshm88 | CFX | 1 | May 16, 2012 06:09 |
