-   ANSYS (https://www.cfd-online.com/Forums/ansys/)
-   -   ANSYS 15.0 for Ubuntu Linux Distribution (https://www.cfd-online.com/Forums/ansys/138130-ansys-15-0-ubuntu-linux-distribution.html)
Crank-Shaft June 29, 2014 01:38
Hello CFD Online,
I've recently tried to upgrade from an older Ansys Workbench release to Ansys 15.0 for my Ubuntu 14.04 LTS based workstation. All I really need is to be able to inspect and modify meshes using ICEM and sometimes post-process or visual results on CFD-Post. Unfortunately, I've only ever had a functional Ansys install on an Ubuntu 12.04 LTS distribution and ever since I've upgraded I've been unable to get this to work.
The installation was performed as root user and then I updated the bashrc file with the PATH for the icemcfd and fluent launchers. Fluent seems to launch from the terminal however, launching icemcfd led to the following error message -
bash: /usr/ansys_inc/v150/icemcfd/linux64_amd/bin/icemcfd: /bin/csh: bad interpreter: No such file or directory
I know this isn't a problem with the PATH I supplied on the bash file since it gives the same error message when launched from the installation directory itself.
Has anyone tried to install and run ansys on Ubuntu 14.04 before? I would really appreciate any assistance or guidance on this matter and I understand that this is not an officially supported distribution.
Thanks
Crank-Shaft June 29, 2014 02:08
Originally Posted by Crank-Shaft (Post 499133)
Hello CFD Online,
Thanks
OK I've solved the problem now -
Just had to install the cshell using apt-get install csh
Hope that helps anyone else stuck with this error.
Thanks
mohamed bassiony July 16, 2014 17:38
arch_varble
hello sir ,
I've recently Installed Ansys 15.0 for Ubuntu 12.04 LTS based server. I have a problem that arch_variable not defined it's my first time to install Ansys for Ubuntu ,if you have any idea how to solve this problem i will be appreciated
Thanks.
gxuxg October 10, 2014 01:47
Originally Posted by mohamed bassiony (Post 501828)
hello sir ,
Thanks.
I assume that you have installed the latest update service pack - 15.0.7. If this is the case, please use fluent launcher and then choose the release 15.0.7 instead of 15.0.0, then your problem will be solved.
tprpr1 October 17, 2015 09:04
hello all
I installed ansys on ubuntu 15.04 however i am unable to run it . can anyone post their modification in the bashrc for the path? im new to ubuntu therefore im unsure.
many thanks
chaitanyaarige April 20, 2017 01:50
Try this
You can directly go to the installation folder ANSYS_Inc
Then V18/Framework
Right click here: open terminal
./runwb2
try this
bobinson May 5, 2017 12:03
Hello all,
Just updated from 14.5 to 16.2 on Linux with following specs:
cat /etc/os-release
NAME="Ubuntu"
VERSION="12.04.5 LTS, Precise Pangolin"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu precise (12.04.5 LTS)"
VERSION_ID="12.04"
The problem is when I start fluent as serial it starts and no problem.
However when in parallel the following error comes up:
Error: eval: unassigned variable
Error Object: rp-3d?
version>
14.5 version did not have any problems. It look like there is some library missing.
Would be very grateful to those who know how to deal with it. Dont want to reinstall the whole system.
Thanks!
