ERROR #002100012 has occurred in subroutine Out_NegVol.| negative ELEMENT volume |
September 3, 2014, 05:19 |
Rep Power: 11 |
My first model is running without problems. But after I change the geometry slightly of that model and re-associate everything. It will give me this error below. This happened also to another different model after changing the geometry slightly. Could someone give me a hint please what I am doing wrong? [the associations are correct and I have done the mesh check too] Thanks +--------------------------------------------------------------------+ | ERROR #002100012 has occurred in subroutine Out_NegVol. | | Message: | | A negative ELEMENT volume has been detected. This is a fatal | | error and execution will be terminated. The location of the first | | negative volume is reported below. | | Volume : -0.1217E-12 | | Location : ( 0.20047E-01, 0.11317E-01, -0.12460E-03) | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver could not be started, or exited with return | | code 255. No results file has been created. | +--------------------------------------------------------------------+ End of solution stage. This run of the ANSYS CFX Solver has finished. |
Display Modes | |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Courant number blowing up, non-orthogonal mesh? | odellar | OpenFOAM Running, Solving & CFD | 5 | October 22, 2013 19:50 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
negative volume encountered | Maga | CFX | 2 | October 7, 2009 17:31 |
