FLUENT or CFX
Old   October 27, 2014, 03:34
Default FLUENT or CFX
Aminul Huda
huda123 is on a distinguished road
I am currently working on a project to study the effect of hydrodynamic forces acting on slings of an object being lifted down onto the seafloor through the splashzone.
May I have suggestions as to whether FLUENT or CFX is the better method for the solver part? I do not have access to ASAS(I wish i had).
Is it better to model the entire system (object, crane vessel, slings, wave tank) in another CAD software I am more familiar with, then import it over to workbench, or is it more appropriate the model the system within ANSYS itself?
Thanks.
huda123 is offline   Reply With Quote
Old   November 13, 2014, 14:22
Ravinder Gill
gill11a is on a distinguished road
Hi Aminul,
I do not have much experience with CFX, but people say that it is better for 3D problems. So if you are modelling a 3D problem, go with it. Otherwise, Fluent is good to use.
In regard to your other question, i is better to create your geometry with ANSYS design modeler. If you are just working on single design( no modifications needed), then you might be able to import the design from other software and work on it. But if you want to change small parameters and re run the simulations, then its way better to do it in design modeler as you don't have to worry about meshing from scratch every time you make a change. Plus, i always find myself into issues when i try to import geometries from any other software into ANSYS.
gill11a is offline   Reply With Quote
Mesh and Solve Times for CFX, Fluent, CD-adapco Jade M Main CFD Forum 4 August 28, 2012 02:54
Import CFX def into Fluent eric_wang FLUENT 0 April 18, 2011 13:14
OpenFOAM vs. Fluent & CFX marco Main CFD Forum 81 March 31, 2009 14:22
Fluent Vs CFX, density and pressure Omer CFX 9 June 28, 2007 04:13
Jobs in cfd - fluent or cfx? jobman Main CFD Forum 6 July 5, 2006 15:02
