Having problem while installing ANSYS 14.0
I'm getting an error while installing ANSYS 14 Products: There was a problem starting the GUI. Please set your DISPLAY correctly or use the silent install (-silent).
I'm asking you for help, have anyone got this problem too? Also I have no idea how to use the silent install. Thanks in advance for any reply (if there will be any). |
By assuming you are on Linux, it means you are trying to start a GUI with no desktop. If you are connecting through SSH, look in your software help to allow X-forwarding and setup Xming on your computer to get the X window.
If you have only a local console session, use the silent install as described in the Ansys Setup Guide pdf. If you are in a local desktop session and having this issue, just type export DISPLAY=:0.0 but this should be already set otherwise your computer will have a lot of issues. Best regards |
Well, i'm not on Linux, i'm on Windows 7 64bit and so is the Fluent version i'm trying to install. This is the webstie I got the program from http://eon.sdsu.edu/~support/ansys/
With this pdf: http://www.kxinc.com/content/Product...on%20Guide.pdf I tried to perform silent installation but with no success. Silent Installation is described in chapter 4.2, I followed the instructions but I'm not really sure if I did eveything correctly. Then I tried this command in Run menu: "<path of the setup file>\setup.exe -silent" still there was no result. If you could tell what am I doing wrong maybe somehow I could defeat this problem. Thank you anyway |
