January 26, 2015, 08:09 |
Hydraulic damper modelling
Ahmed Hagi
I'm currently researching hydraulic dampers for the rail industry.
The program in question is Ansys. I'm not experienced with CFD but it is essential to this project. I need to model a cylinder with a piston that moves inside of it at a certain velocity. The cylinder is to contain a set volume of silicone oil. I would like to see the pressure distribution and the flow conditions within the cylinder as the piston moves to compress the oil. How would I go about doing this? Thanks for taking the time to read this and for any and all responses. I've added a simple diagram to help explain better. Last edited by jiggypepper; January 27, 2015 at 05:40. Reason: Adding a simple diagram |
damper, dynamic piston, fluid, hydraulic, pressure |
Modelling hydraulic structure in OpenFoam | mukesh499405 | OpenFOAM | 0 | April 16, 2013 06:08 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
hydraulic diameter in 2d | ahsan | FLUENT | 2 | August 28, 2009 15:22 |
Importance of Hydraulic Diameter Value for Compressible Flow | RyGuy | FLUENT | 0 | August 6, 2009 10:58 |
Advice on multi-phase flow modelling | Martin | Main CFD Forum | 3 | October 14, 2008 05:16 |
