Uninitialized flow field
Like Tree1Likes
  • 1 Post By S.N
Old   March 31, 2015, 10:23
Exclamation Uninitialized flow field
Anwar
4asino is on a distinguished road
In fluent, I've solved a case , then wanted to write a profile from setup>boundary condition>profile>write ... to read it again in a new case boundary condition but the result was an error of "Uninitialized flow field".what is the solution ?
Also can this problem be solved in CFX ?
4asino is offline   Reply With Quote
Old   April 27, 2017, 13:15
Default Error: Iterate: uninitialized flow field
S.N
Niki
S.N is on a distinguished road
Hi
I have problem calculating the solution in fluent. Once I initialize and then hit the calculate bottom the following error occurs:
" Error at Node 6: Iterate: uninitialized flow field
Error Object: #f "
Does anybody know how to solve this problem and why this error comes up?
Thanks
ilyes64 likes this.
S.N is offline   Reply With Quote
Old   April 27, 2017, 23:30
Lucky
Two things.
1. Try in serial mode.
2. Make sure you are not doing any post-processing that expects variables to exist, although this would normally throw a segmentation fault.
Old   April 28, 2017, 14:39
S.N
Niki
Originally Posted by LuckyTran View Post
Two things.
Thanks a lot Lucky
Actually I tried parallel form but again I had similar error :
Error Object: #f
And also I don't have any post processing.
Again thanks for your help
Old   April 28, 2017, 21:59
Lucky
Did you initialize it in serial?
Make sure you initialize the case and then read in the profile.
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 07:56
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 07:30
velocity of massless particles and velocity of flow field in same coordinate payam_IUST FLUENT 0 October 18, 2009 23:24
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
