Thrust failure: bad allocation: out of memory ERROR
Old   April 20, 2015, 05:51
Default Thrust failure: bad allocation: out of memory ERROR
deadshot
meen_far is on a distinguished road
HI,
I am facing a pertinent problem while using Ansys 15.07 in a Dell Precision T7610 Workstation having 64GB RAM and 1 NVDIA Tesla K20 card for GPU. The following error message is is being displayed every time for running GPU based solver be it Fluent or Structural solver.
AMG on GPGPU
NVAMG version 4
Built on Aug 21 2013, 13:02:58
File and line number are not available for this exception.
NVAMG ERROR: file ..\..\src\amg_gpu.c line 905
NVAMG ERROR: Thrust failure
Error: There is no active application.
Error Object: (case-modified?)
MPI Application rank 0 exited before MPI_Finalize() with status 1
Error Object: (data-valid?)
Can anybody comment in this context?
Thnks in advance.
meen_far is offline   Reply With Quote
Old   April 21, 2015, 03:24
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Does the simulation run without this error on the CPU only?
flotus1 is offline   Reply With Quote
Old   April 21, 2015, 12:34
deadshot
yes the simulation run if i uncheck the GPU setting, it run without this error on CPU only
but i did the simulation before with GPU checked (same pc, same specs, few days back actually i run the simulation on both GPU and CPU, it was running fine, without any error watsoever. thats y i dont understand why for a specific model, when i check the GPU option, i get the error message. i create a new geometry, new design to test, and the simulation doesnt run if enable GPU and CPU...
Old   April 21, 2015, 12:44
flotus1's Avatar
Alex
Are you sure that it was the EXACT same simulation? Same number of cells, same models activated?
I am asking since the error message suggests that the model requires more memory than the GPU can provide.
Just out of curiosity: why are you using the GPU?
The vast majority of benchmarks I have seen so far suggest that running in parallel with the GPU actually increases simulation times for most models.
Old   April 21, 2015, 13:18
deadshot
no no, the simulation had different setting, more cells, more nodes, the model was slightly more complicated than the previous one. But now it makes sense. i didnt understand the exact meaning of the error message. hopefull i did manage runing the sim without the GPU on.
Oh interesting. i read somewhere that if combining gpu and cpu for simulation, the simulation will take less time. thats y i was using the gpu as well. but now that u pointed it that its the other way around, i wont be bothering using the gpu for future. Thanks a lot for clarifying. You guys rock (Y)
Old   March 6, 2017, 02:31
Lightbulb
rose doll
nikoshiya is on a distinguished road
Originally Posted by meen_far View Post
HI,
AMG on GPGPU
NVAMG version 4
Thnks in advance.
I take the following answer from Dell Precision T7610 Manual, if you face any issue in implementing these steps. Then check manual for detailed view.
Run Registry Editor (Regedt32.exe).
From the HKEY_LOCAL_MACHINE subtree, go to the following key: \System\CurrentControlSet\Control\Session Manager\SubSystems.
Select the Windows value.
From the Edit menu, choose String.
Increase the SharedSection parameter.
nikoshiya is offline   Reply With Quote
Old   January 22, 2018, 05:56
Default Similar Problem
Hells Blade
hellsblade.91 is on a distinguished road
i am also facing the same problem the simulation runs when i dont use the double precision option but with double precision i get this error
I increased the no of nodes and elements ie made the mesh much finer
hellsblade.91 is offline   Reply With Quote
Old   January 22, 2018, 06:01
flotus1's Avatar
Alex
Are you asking for advice or just stating a fact?
Your model does not fit into GPU memory, so it can nut be run using GPU acceleration.
Old   January 22, 2018, 06:40
Hells Blade
Hi I am seeking advice do you know the solution is it due to increased no of elements due to mesh being finer
Old   January 22, 2018, 06:46
flotus1's Avatar
Alex
Possible solutions:
  • run smaller models that fit into GPU memory
  • decrease memory usage by other means, e.g. by using single precision instead of double
  • buy a GPU with larger memory (or several of them)
  • not using GPU acceleration at all
There are no workarounds for this issue. If the model does not fit into GPU memory, you can not run it with GPU acceleration.
Old   January 22, 2018, 06:59
Hells Blade
How do i run it with a GPU Acceleration do you know ?
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
Problems of Duns Codes! Martin J Main CFD Forum 8 August 15, 2003 00:19
