July 21, 2015, 04:06 |
Problem: Generating Stiffness Matrix (HBMAT)
Max
Rep Power: 10 |
I struggle to use the HBMAT command in ANSYS Mechanical to generate a text-file which includes the global stiffness matrix of my part by enter the following codes into a command block: Code:
HBMAT, Z:/Test1, .txt, --, ASCII, STIFF, YES, NO Code:
aux2 file,file,full hbmat,Z:/Test1,.txt,,ascii,stiff,no,yes fini Code:
/solu antype,substr seopt,file,2,1 m,all,all /output,M5x5 solve /output Best regards, Max |
Output Stiffness Matrix ANSYS Workbench | USER1234 | ANSYS | 1 | July 13, 2015 21:45 |
Generating coefficient matrix | mahdi_kh8 | Main CFD Forum | 4 | July 13, 2015 03:52 |
run Doxygen offline | anishtain4 | OpenFOAM | 8 | November 27, 2014 09:36 |
[blockMesh] Problem in generating mesh for axissymmetric domain | krishtej23 | OpenFOAM Meshing & Mesh Conversion | 2 | February 7, 2014 14:20 |
problem about direct solver for sparse matrix | ztdep | Main CFD Forum | 0 | August 11, 2006 12:16 |
